which is better?
Old Feb 10, 2009 | 07:17 PM
smoke247's Avatar
Default which is better?
Im looking for more torque out of my b16a which bottom end is better using a b18b or b18c? anyone? which is cheaper?
Old Feb 10, 2009 | 08:29 PM
jsant07's Avatar
Default Re: which is better?
search
Old Feb 10, 2009 | 08:33 PM
raidacaipo's Avatar
b18b is better only if you want to go ls/vtec = more displacement
b18c1 with a b16 head will lose compression
b18c with a b16 head will kinda be like an itr but your using a b16 head
b18b(ls)= cheap but you should have it built and you must tap your b16 head for an oil line
b18c1(usdm gsr)= expensive block and you will lose compression. A b18c1 head is best for it
b18c(jdm itr)= SUPER EXPENSIVE BLOCK! if you get a good deal then I say get that and use your b16 head.
out of all the torque in the world for 1.8 liters then the b18b block is the best = ls/vtec and if you want the ultimate B series torque master than a b20 block is best = b20/vtec
Old Feb 10, 2009 | 08:47 PM
nengx07's Avatar
im gonna say b20z block bc im running b20V xD.. beasting torque machine
Old Feb 10, 2009 | 08:52 PM
ALLxMOTOR EG's Avatar
Vietnamese!
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
b20 block mate with b16 head.
ALLmotor_89
Mar 21, 2010 05:08 PM
egeeb16
Mar 2, 2006 07:37 AM
kevinoneill
25
Sep 26, 2003 10:17 AM
94obd1vtec
Jun 19, 2003 03:17 PM
nasteboyii
Jul 29, 2002 12:08 AM
