How To Install a Oil Catch Can?
Old Feb 10, 2009 | 06:55 PM
EHracer06's Avatar
Default How To Install a Oil Catch Can?
I'm not sure where the pcv is located on my intake manifold,
that I run to the Oil Catch Can
Anyone have pix or better yet a How-To?
What size hose do I use?
I feel like a newb lol.
Old Feb 11, 2009 | 08:09 AM
EHracer06's Avatar
Default Re: How To Install a Oil Catch Can?
anyone? I know someone here has put a catch can on a d16z6
Old Feb 11, 2009 | 08:24 AM
Unseen Racer's Avatar
https://honda-tech.com/forums/forced-induction-16/official-crankcase-evacuation-thread-turbo-hondas-pcv-catchcan-1199935/
https://honda-tech.com/forums/showth...=catch+can+oil
take your pick. and there is MORE IF YOU SEARCH
Old Feb 11, 2009 | 08:25 AM
buddy190's Avatar
You know that breather hose that goes from the intake pipe to the valve cover...? I think they just replace that hose with one that has a filter in the middle.
Old Feb 11, 2009 | 08:37 AM
1LowSol's Avatar
This shows a lil better.. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-civic-d16z6-pcv-valve-location-pic-2438600/
All you gotta do is search.. it's very simple
Old Feb 11, 2009 | 10:14 AM
EHracer06's Avatar
thx guys
so I run the hose from the PCV to the catch can along with valve cover vent hose? what do I do about the plug in on the intake manifold?
Old Feb 21, 2009 | 09:53 AM
Kahuna9889's Avatar
Originally Posted by EHracer06
thx guys
Anyone?
Old Feb 21, 2009 | 10:11 AM
teggrl's Avatar
am i the only one that is haveing search probles I can even search gsr or b16a2 nothing bump for you
Old Feb 22, 2009 | 08:19 AM
dimitarnc's Avatar
Hi I'm too at the moment installing catchcan. I read a DIY article about the catchcan setup on the back of the Honda B20 block. I have the Honda fittings, but I think they are too heavy to be aluminum. Will there be a problem when the engine heats up end there is heat expansion - both the block and fittings? If they are different alloys? I attached a image of what I have from the local Honda dealer. Second question is about the washers - they really seem to be aluminum (very lightweight) - should I use them as is (only crush them when screwing) or there is need to apply some teflon tape?
The fittings:
The washers:
Old Feb 22, 2009 | 08:34 AM
TheRappist's Avatar
Originally Posted by Unseen Racer
MORE IF YOU SEARCH
Shut the hell up.
Old Feb 22, 2009 | 09:11 AM
Andr3w's Avatar
There's about a million different ways you can go about it
i have a hose from my crancase and valve cover going to a vented can.
but you could also use a vacuum pump.. exhaust slash cut,intake slashcut to pull vacuum in a non vented can etc etc.
Old Feb 25, 2009 | 09:21 PM
EG8R's Avatar
The fittings:
The washers:
I would say teflon tape is not needed if you are using the gasket.
And as far as them being 2 different materials and heating up. I would not worry too much about that. The plugs that are in there now are not aluminum either.
Old May 27, 2009 | 09:31 AM
gettin it's Avatar
Searched alot. Im trying to get the part numbers for the fittings. Did anyone get them yet?
type B16
Sep 24, 2006 04:14 PM
graphic
Oct 9, 2003 08:36 PM
Rick
Sep 27, 2003 05:33 AM
-Whitey-
Sep 28, 2002 09:36 PM
supergreenNA1
Jul 16, 2002 03:20 PM
