SC61 .81 A/R on 81.5mm GSR??
Old Feb 10, 2009 | 12:13 PM
Project_EK's Avatar
Default SC61 .81 A/R on 81.5mm GSR??
what up,
i have a semi built 81.5mm gsr (ls crank, eagle rods, CP 9.1 pistons,) w/ built head. i'm looking to go with a SC6162 .81AR w/ S 4" ported comp. cover. i already know that this turbo will have lag but im looking to make high 400 on pump and 550 on race fuel. about where would i have full boost? i'm just worryed about falling out of boost between gears?? i seen a graph on evans site with someone on a simular build and he made 500 on pump (same turbo) and he said the lag wasnt as bad as ppl say?! i'd just like to get more input from ppl with this turbo
thanks
Old Feb 10, 2009 | 12:49 PM
alexsracing's Avatar
Default Re: SC61 .81 A/R on 81.5mm GSR??
I have a sc6152s .63 now and full boost by 5k rpm to redline 9300rpm
upgrading to sc6265SP billet wheel .82 will see the spool diff when it comes in
Old Feb 10, 2009 | 02:32 PM
turbo-crx's Avatar
depending on tranny and rev limit you shouldnt fall out of boost.
Old Feb 10, 2009 | 02:39 PM
Project_EK's Avatar
i have a GSR tranny...id prolly be revving to 9.5k
Old Feb 10, 2009 | 02:40 PM
Project_EK's Avatar
if u dont mind me asking, what kind of power did u make with this turbo?? what size engine?
Old Feb 10, 2009 | 02:46 PM
turbo-crx's Avatar
shouldnt have an issue as long as you have a good clutch
Old Feb 10, 2009 | 05:03 PM
91TurboGSRCRX's Avatar
what size back housing is it...
Old Feb 10, 2009 | 07:53 PM
GregUnit's Avatar
I had the same turbo on a B16 reving it to 8700 and it was fully boost by 5000 5200 and held to rev limit and didnt fall out between shifts.
Old Feb 11, 2009 | 04:47 AM
Project_EK's Avatar
^thats the response i wanted to hear!! as long as i can have full boost by 5.5k RPM i'm happy..
Old Feb 11, 2009 | 05:43 AM
my engine is gsr 2.0l, on stock gsr cams ran 10.8@134 with the .63 hot side
b16 tranny with quaife ,broke 4th gear later, now have ls tranny with quaife
Old Feb 11, 2009 | 05:58 AM
cotorresgee's Avatar
I had the percision SC6152E .63 hot side and hit full boost about 5k with a rev hard cast manifold setup was stock sleeves eagle rods wiseco piston GSR block and crank. stock b16 head with gsr cams. car made 550'ish HP and ran 10.4@136 revving to 9500 rpm and using VP q16 race gas
Old Feb 11, 2009 | 06:35 AM
Project_EK's Avatar
nice! what did u make on pump??
i keep hearing good things about the SC6152E
Old Feb 11, 2009 | 09:44 AM
Never tuned on pump gas...strictly a street class race car
Old Feb 11, 2009 | 01:48 PM
InTeGrA GsR 321's Avatar
Icon5 Re: SC61 .81 A/R on 81.5mm GSR??
Get them S2 Tuner 1's to pick up spool and power kidd...
Old Feb 11, 2009 | 05:36 PM
Turbo-LS's Avatar
turbo will be fine, im running a stage 5 turbine wheel with a .82 hotside sc63 16 psi by 4500 rpm reving to 9k and it doesnt fall out of boost unless shift below 8k and the responce time isnt bad at that point either
this is on a stroked gsr 81.5mm srp's 9.7:1 actual compression scat rods ctr cams stock gsr head and gsr trans with spa cast topmount.
96accordsir
Dec 14, 2012 06:31 PM
jimmyizcool
Dec 29, 2007 03:13 PM
onemoreday21
Nov 29, 2005 05:11 AM
incredteg3
Nov 2, 2004 06:22 PM
ForgedSleeper
Mar 21, 2004 07:45 PM
