95 accord front end problem
Old Feb 10, 2009 | 11:25 AM
dwilkerson's Avatar
Default 95 accord front end problem
I just replaced both of my cv axles to fix a knocking noise. It is still making the noise when I turn to the right any ideas of what the problem could be??
Old Feb 10, 2009 | 12:15 PM
Scrapin4DR's Avatar
Default Re: 95 accord front end problem
Sounds like wheel bearing, check your control arms too.
Old Feb 10, 2009 | 12:44 PM
P_Adams's Avatar
Are you noticing anything else. Does it knock:
Going Straight?
Taking Corners?
Going Over Speed Bumps?
Backing up?
Applying Brakes?
Does it Knock if you bounce the Body?
P
Old Feb 10, 2009 | 01:47 PM
dwilkerson's Avatar
Ok so it does it going straight if I correct the wheel to the right, it does when I take a right turns but not left. It doesn't do it when I push the breaks, backing up that I noticed. I am not sure about when the body bounces or going over speed bumps.
Old Feb 10, 2009 | 04:21 PM
P_Adams's Avatar
Check the steering racks' tie rod ends (both inner and outter) / both sides.
P
Old Feb 11, 2009 | 09:41 AM
dwilkerson's Avatar
So I took the car to my mechanic and he said that he thinks it might the front motor mount does this sound possible? He checked the tie rods said they seemed fine. Thanks for all the help!!
[S]niper[W]olf
May 19, 2015 06:06 AM
wesk18
Jan 27, 2009 04:51 PM
mikeszutu
Jan 24, 2009 07:30 PM
rgroseclose@mcs.k12.nc.us
Jan 15, 2009 08:57 AM
