bad thermostat?
Old Feb 10, 2009 | 07:59 AM
teddy_dc2's Avatar
Default bad thermostat?
for a while now the teg takes forever to warm up. driving to work like 15 miles away the temp only reads a little past the starting point and car doesn't seem that powerful at top end. could it be a bad thermostat like stuck open? is this bad? car is turbo and using an aftermarket civic radiator btw.
Old Feb 10, 2009 | 08:36 AM
mouab18c1's Avatar
Default Re: bad thermostat?
could be a bad theromstat...you could also have air bubbles in your coolant system.try replacing the thermostat with a new one..their cheap
Old Feb 10, 2009 | 08:40 AM
teddy_dc2's Avatar
haven't replace the thermostat since i got the car like three years ago and haven't change the coolant for almost a year and a half. will this cooling problem affect the engine? seems my vtec doesn't work properly when it is cold.
Old Feb 10, 2009 | 08:46 AM
mouab18c1's Avatar
yes your coolant systems affects your vtec alot...vtec only engages to full potential when your car is at normal operating temps...like i said best way to go on this is replace the thermostat...and bleed your coolant when you install the new one...check for leaks anywhere...that could also be a cause
Old Feb 11, 2009 | 01:19 PM
honda1982's Avatar
I thought for sure Vtec engage when there's good amount of oil pressure not COOLANT temp..Maybe I'm wrong...
Old Feb 11, 2009 | 01:55 PM
alteclansing's Avatar
nope V-tec only engages once the motor has warmed up.
Old Feb 12, 2009 | 06:45 AM
mouab18c1's Avatar
correct vtec only engages when the motor is at normal operating temps...if not it will cut off
Old Feb 12, 2009 | 07:31 AM
ekb16's Avatar
ur tstat is stuck open..happen to my car a few months ago
grimview
Jul 22, 2013 03:32 PM
themiz816
Jan 12, 2013 08:57 AM
mikeryan161
Dec 16, 2012 03:36 PM
rebuiltSI
Jun 7, 2007 01:14 PM
Pat
Jan 27, 2002 05:12 PM
