vtec question?!?!?
Old Feb 10, 2009 | 01:54 AM
ls_bitik's Avatar
Default vtec question?!?!?
how come my vtec is not engaging as loud as before but it pulls hard tho. i ran over a rock and shut 2 pipes on my headers. do you guys think its the oil pressure from the block? any ideas?
Old Feb 10, 2009 | 02:01 AM
SleeperGSR's Avatar
Default Re: vtec question?!?!?
Sounds like your headers arn't headering. I don't know what you mean by "shut 2 pipes" but if you have restricted flow that can be why your vtec isn't loud. Sounds like you might need a new one. I think someone else suggested adding an amp to your vtec if really you wanted it to pop. Good luck
Old Feb 10, 2009 | 02:05 AM
ls_bitik's Avatar
haha sorry... i meant like shut closed. i wasnt too clear. i was just wondering because before it happened, it was loud. it still pulls the same tho. any idea on what happened?
Old Feb 10, 2009 | 02:09 AM
SleeperGSR's Avatar
Might have something to do with your problem
Old Feb 10, 2009 | 02:12 AM
ls_bitik's Avatar
i already changed it to itr headers. still not the same as before.
Old Feb 10, 2009 | 06:42 AM
aemintgsr's Avatar
Did it damaged your oil pan?
Old Feb 10, 2009 | 07:01 AM
pmey's Avatar
well if your getting no check engine light and vtec still engage. I would just leave it alone "vtec is suppose to be a smooth transaction". so you should be good
Old Feb 10, 2009 | 07:19 AM
Shawn C's Avatar
In The Garage
when you smashed your header, it may have caused a shitload of buildup in the head ports in those cylinders, maybe?
Old Feb 10, 2009 | 12:30 PM
ls_bitik's Avatar
i still dont know what happend. no check engine light, engine runnning smooth, no problem. just curious on what caused it. maybe the oil pressure at the block? u think so??
BlueSmartEm1
13
Jul 3, 2011 09:26 PM
crowder13
Mar 5, 2007 07:25 PM
RedSiRacer
29
Jan 19, 2006 09:56 AM
CompressionFed
Mar 23, 2004 04:54 AM
fso_BamBam
Jun 26, 2001 04:13 AM
