25mm spacers 4x100
Old Feb 9, 2009 | 06:18 PM
frmdstryr's Avatar
Default 25mm spacers 4x100
Hi has anyone used these spacers before?
http://cgi.ebay.com/ebaymotors/_Car-...3A1|240%3A1318
I slammed my teg, but it's got like 3" of a gap between the tire and the wheel-wells. The search is down, so sorry if someone already posted this...
Old Feb 9, 2009 | 06:47 PM
toyomatt84's Avatar
Sanji
Default Re: 25mm spacers 4x100
Anything over 10mm, and you'll need extended lug studs.
Old Feb 9, 2009 | 06:48 PM
frmdstryr's Avatar
These have nuts that go on the stock lugs then they have extra lugs that extend out of the spacers.
Old Feb 9, 2009 | 10:56 PM
r.wright's Avatar
you will rub most likely but i have used spacers like those up to 30 mm and never had a problem but just make sure everything is torqued correctly and you are using the correct sized lug nut on top of the adapters so the nut is properly seated to prevent any type of vibration.
F20Cdriver
Oct 7, 2011 03:32 PM
HCivExoo
Jan 18, 2009 06:36 AM
boostincoupe
Jun 30, 2008 06:03 PM
VTECAcuraGSR
13
Mar 24, 2003 04:29 PM
TurboLude97
Feb 2, 2003 01:56 PM
