Installed NGK wires. Now its making knockin noises
Old Feb 9, 2009 | 10:57 AM
91akira's Avatar
Default Installed NGK wires. Now its making knockin noises
I removed my 12 year old aftermarket Magnacor wires for NGK blues. Now I'm hearing the engine making knocking sounds. What is it my valves? How did that come to be?
I have V-power NGK plugs by the way.
Old Feb 9, 2009 | 11:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Installed NGK wires. Now its making knockin noises
Most likely just a coincidence and not actually caused by the new plug wires. Put the old ones back on to be sure, though.
Also, verify that you have the wires in the correct order on the distributor cap. If not, the engine will run very poorly (happened to me once).
Otherwise, the engine may need a valve lash adjustment, or a worse possibility is that one or more lost motion assemblies has gone bad.
Old Feb 9, 2009 | 11:22 AM
91akira's Avatar
Yeah I don't think my new wires are the problem cause I put back the old wires and there still making the noises.
Do you mean valve adjustment? Is there a how-to procedure anywhere?
Old Feb 9, 2009 | 11:39 AM
Community Builder
http://www.c-speedracing.com/howto.php has a good write-up.
Are you sure you have the wires installed in the correct order on the distributor cap? How loud/bad do the noises sound? Like just a slight ticking sound or a loud knocking sound?
Old Feb 9, 2009 | 12:11 PM
91akira's Avatar
I'd say you can't hear it in the car. Only when you pop the hood and your just standing in front of the engine, you can hear the noise. If you have a desk in front of you, use your knuckles and tap the desk repeatedly. Thats what it sounds like.
Old Feb 9, 2009 | 10:00 PM
jhammond_82's Avatar
Reject Papi
take a sound vid and post it up here.
motegicivic
13
Mar 25, 2012 02:18 PM
asianman139608
Apr 28, 2008 11:36 AM
bensebold
Jul 30, 2006 09:44 PM
