Type R Vavles in a b16 head?
So i have a Type R head that is Fuxed. I am taking the valve terrain and rocker arms and putting them into a b16 head. Will the Valves from the type R head fit into a b16 Head or does the .2 leter displacment make a diff so that there too big?? And can a machiene shop fix this?
Only the ones in that cylinder are fubar'd. The rest are fine. I have a bunch of other type R valves laying around from other projects that im goin to use to replace them.
Any one know if a machiene shop can fix this??
yes, but you'll pay out the *** for them to fix it by welding/reshaping the combustion chamber. My buddy had a head fixed that dropped a valve. It was like $500 CDN to fix the 1 combustion chamber IIRC
If you are using valves from 1 motor into a 2nd motor a valve job would almost be neccessary to make sure they seat correctly. Of course you prolly already know this though.
Sr420Det
Mar 20, 2009 01:25 AM
Sr420Det
Mar 19, 2009 05:57 PM
