Power steering removal???
Old Aug 8, 2002 | 05:01 PM
1.8EG-T's Avatar
Default Power steering removal???
Is there any certain way to remove power steering from a vehicle...I am sure that I heard somewhere that you can not just remove the pump and the lines, that something else needs to happen. I am just trying to confirm this before I do this. Thanks for you r help and I did a search, but it only confused me more.
Old Aug 8, 2002 | 06:04 PM
poison's Avatar
Default Re: Power steering removal??? (hybridrex)
yes you can remove the power steering pump, and lines and what not, the other thing u don't 'need' to get but would be easier to steer w/o power steering is a non-power steering rack.
hth
Old Aug 8, 2002 | 07:46 PM
2000_Civic_Si's Avatar
Default Re: Power steering removal??? (poison)
What i did on my car tempo. is remove everything and just run the 2 line back to one another to make 1 continuous line. that way the fluid stays in the rack but flows back and forth so the piston moves frelly lubed up and everything. It owrks for me until i get a non-powersteering rack.
Old Aug 8, 2002 | 08:03 PM
poison's Avatar
Default Re: Power steering removal??? (2000_Civic_Si)
whoa, what now? is it a lil easier to move the steering wheel? i just removed all my power steering items (exept the lines) and let 'em sit, i like the feel of the road and what not, but this doesn't cause any damage now does it?
Old Aug 8, 2002 | 11:28 PM
The reason i roued the lines back to the other one is cause it keeps the rack lubed...if you dont keep it lubed it could get stuck in a midde of a turn and that woudl suck not being able to turn the wheel. It is very unlikly but it is a goo didea to do what i mentioned to keep this from happening. If you got any ?'s email me or Pm here on H-T.com
Later,
Jay
highschooler
Aug 3, 2004 05:01 AM
mattcalica
Jun 29, 2004 11:10 PM
bUy..mY..cIvIc
Jan 8, 2004 06:16 PM
