where is the trans fluid dipstick
Old Feb 8, 2009 | 02:43 PM
niceprelude's Avatar
Default where is the trans fluid dipstick
is this where i fill the trans fluid
Old Feb 8, 2009 | 02:59 PM
teamworxek9's Avatar
Default Re: where is the trans fluid dipstick
No, that is where you fill it. There isnt a dip stick you remove the plug on the other side and down a bit, thenfill it till fluid comes out. It will be a plug with a spot for a 1/2 rachet, do not over tighten it.
Old Feb 8, 2009 | 03:58 PM
on top or on the side
Old Feb 8, 2009 | 04:05 PM
01d17's Avatar
on the side
Old Feb 8, 2009 | 04:07 PM
talon2066's Avatar
the drain plug uses a 3/8" ratchet on this side at the bottom, and just above it a bit, almost level with the axle hole is a 17mm plug, fill it till it runs out. If your axles aren't in it well leak out there instead
Old Feb 8, 2009 | 04:12 PM
how am i suppose to fill on the side
Old Feb 8, 2009 | 04:14 PM
lcsej1's Avatar
i think that up top is just a breather hole not sure so don't flame me for this. but the filler plug is located near the axle and it is a 17mm bolt. fill it till fluid comes out of that hole then close it. never overtighten it you could crack the aluminum or ruin the threads!
Old Feb 8, 2009 | 04:15 PM
Meoshe's Avatar
You can remove the vss and fill from there. Just make sure you have the side plug off so you know when you are at the right level.
lcsej1's Avatar
you can get yourself a funnel with a flexible end so you can fill it!
Old Feb 8, 2009 | 04:17 PM
talon2066's Avatar
funnel with a rubber hose is what i use, think i got it at farm n fleet or something, works great!
Old Feb 8, 2009 | 04:20 PM
thanks very helpful
northkai3
26
Sep 29, 2013 11:53 AM
blouthan
Transmission & Drivetrain
Mar 6, 2009 05:01 PM
EG_Civic_Si
Feb 4, 2006 12:42 PM
Adam_F123
Nov 25, 2005 11:05 AM
hb_racer
Mar 2, 2002 06:20 PM
