puting b16a in crx, where can i get gauge clusters?
Old Aug 8, 2002 | 03:36 PM
CRXhf90's Avatar
Default puting b16a in crx, where can i get gauge clusters?
just wondering how to go about getting new tachs that will fit in 90 crx. redline at 8k in mph. also, considering coilovers or springs? which is better, cheaper, etc.?
Old Aug 8, 2002 | 03:38 PM
EL Vap133's Avatar
Default Re: puting b16a in crx, where can i get gauge clusters? (CRXhf90)
Springs are usually cheaper, coilovers are better...
Old Aug 8, 2002 | 05:48 PM
bryant's Avatar
Default Re: puting b16a in crx, where can i get gauge clusters? (Vap133)
for the guage cluster. check out eBay for the JDM cluster.
Edit: Kennewick, WA? I used to live there. And still know ppl that do.
[Modified by CR-X, 8:49 PM 8/8/2002]
Old Aug 8, 2002 | 06:07 PM
DJ KrunchyKracker's Avatar
Default Re: puting b16a in crx, where can i get gauge clusters? (CR-X)
i thought i heard some people talk a while ago about the euro crx gauge cluster having the 8k redline and the speedo went to 145 or somethin like that.
Old Aug 8, 2002 | 06:09 PM
E-AT_me's Avatar
Default Re: puting b16a in crx, where can i get gauge clusters? (TheRZA28)
why do you want a new cluster? you can use the stock
Old Aug 8, 2002 | 06:34 PM
CRXhf90's Avatar
Default Re: puting b16a in crx, where can i get gauge clusters? (Rexman)
my stock cluster redlines at 5k.....just want a SiR look. also, instead of getting a whole new cluster, could i just get new rpm and speedometer numbers and install them? can that be done and still read correct speed?
[Modified by CRXhf90, 4:00 AM 8/9/2002]
Old Aug 8, 2002 | 06:36 PM
CRXhf90's Avatar
[QUOTE]
when did you live here?
Old Aug 8, 2002 | 06:53 PM
bryant's Avatar
umm in the begging of high skool and middle skool i lived there.. left in '00
Old Aug 8, 2002 | 06:59 PM
xXx Justin xXx's Avatar
[Modified by CRXhf90, 3:51 AM 8/9/2002]
i don't think so because if you ever take apart your dash. the needle is still going to move the same rate but the numbers on the Sir are crammed closer together. therefor it would be reading a higher rpm then it really is. but you might be able to get everything re-calibrated or something?
Old Aug 8, 2002 | 07:01 PM
EF8_SiR's Avatar
Not sure if this is totally accurate but I believe there's something different about the JDM gauges in terms of wiring. It's possible but u might need to find a source that will show u the wire change ups (it's not a direct plug and play)
Old Aug 8, 2002 | 07:03 PM
CRXhf90's Avatar
right on.....i graduated in '00
will that ac work w/ a b16a swap?
Old Aug 8, 2002 | 07:44 PM
Taloola's Avatar
http://www.jdmfan.com/technical/cosmetic/sir_cluster/
this will help with the wiring of the jdm cluster
Old Aug 9, 2002 | 10:05 AM
bryant's Avatar
Default Re: puting b16a in crx, where can i get gauge clusters? (gokoolFL)
Grad. in '01 here.
Yes A/C will work, you just have to get the braket from HASport.
Old Aug 9, 2002 | 10:45 AM
ricodemus's Avatar
I've left my stock si cluster in for now. It read all the way up to 8k, thats fine with me. My jdm cluster is sitting in a box, maybe I'll feel like puttin it in one day, but not right now.
Old Aug 9, 2002 | 11:26 AM
Brandon Chun's Avatar
Default Re: puting b16a in crx, where can i get gauge clusters? (ricodemus)
I had an Sir cluster I think you also need an electronic vehicle speed sensor to run it. Changing from miles to kilos I didn't like though so I never got around to changing the cluster.
Old Aug 9, 2002 | 01:28 PM
HondaDriver85's Avatar
Default Re: puting b16a in crx, where can i get gauge clusters? (Brandon Chun)
just buy a monster tach. looks cooler and u can set shift points
Old Aug 10, 2002 | 07:18 PM
Stop the Beast's Avatar
I was looking for one today they said they would get some in a container in the next 2 weeks.
[Modified by brokstar, 9:18 PM 8/10/2002]
[Modified by brokstar, 9:19 PM 8/10/2002]
Damn technology!
Old Aug 10, 2002 | 07:33 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: puting b16a in crx, where can i get gauge clusters? (brokstar)
Thats what I am saying
don't buy monster
get a small 3 3/8 tach in the corner
no point in spending on a tach that might nt work properly
THE GREEN CRX//
Jan 13, 2011 01:58 PM
sikefcrx89
Nov 16, 2009 04:13 PM
B16PMPN
Jul 6, 2005 01:44 AM
REDBARON
11
Jul 3, 2001 08:07 AM
