Dimming Headlights
Old Feb 7, 2009 | 04:11 PM
MeyekulBayrd's Avatar
Default Dimming Headlights
I couldn't search for this so here's my question.
I have a 00 DX hatch. The problem is the headlights will dim then brighten and they don't do it according to rpm. Any ideas? It's dark so I'm going to check for loose connections tomorrow.
Old Feb 7, 2009 | 04:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Dimming Headlights
start by checking the sockets.
Old Feb 7, 2009 | 04:25 PM
I'm going to borrow a volt meter from work as well. I'm new to Hondas, cars anyhow, and didn't know if it was a common problem. I've been looking through the stickies.
Old Feb 7, 2009 | 04:33 PM
Mr. Badwrench
i know sockets are an issue. usually they build up a little resistence then start to melt.
Old Feb 7, 2009 | 04:34 PM
Thanks. That'll be the first thing I check out in the morning.
Old Feb 7, 2009 | 06:20 PM
CALIGUYCRX's Avatar
Check voltage and loose grounds at times will also either turn the headlight off of dimm , or also could be charging system is failing?
Old Feb 7, 2009 | 06:43 PM
The car just came from Michigan so it may be some salt corrosion. I'm going to check everything though.
Old Feb 7, 2009 | 09:04 PM
SiYouLater's Avatar
Bad alternator?
Old Feb 7, 2009 | 09:16 PM
SOHC_4dr's Avatar
i think you could have a bad alternator. to do a quick check, let your car idle with the lights on and see the voltage at the batt, it should read 14.6v
Old Feb 8, 2009 | 05:34 AM
I forgot that my neighbor is a mechanic. I'm going to pull it in the garage after I drink my coffee and eat some breakfast. My gf said, "It does it everytime the motor moves." Hopefully it's something simple that I can fix today.
Old Feb 8, 2009 | 08:51 AM
Turns out it's the battery not holding the correct charge.
Old Feb 8, 2009 | 01:15 PM
Ok.. Wrong.. Alternator is only putting out 37amp.
Acme_EK_Hatch
Jun 4, 2012 03:00 AM
psyrage19
Feb 25, 2008 04:01 PM
fe519
Apr 12, 2006 11:01 AM
civcexcoupeblack
Jun 23, 2003 04:34 PM
chris408
Apr 3, 2003 10:46 PM
