Balancer belt replacement done incorrectly
Old Feb 7, 2009 | 05:34 AM
ozvena's Avatar
Default Balancer belt replacement done incorrectly
The "expert" missed this step on my 99 Accord:
'Align the rear balancer shaft pulley by using a 6 x 100 mm bolt or equivalent as an alignment tool. Scribe a line 74 mm (2.9 in) from the end of the bolt. Insert the bolt into the maintenance hole to the scribed line.'
The engine was starter and raved few times after he missed the step.
The moment I turned the ignition key I noticed that something is wrong, vibration.
Please tell me that there is no damage to the engine and that all what needs to be done is to do the missed step.
Please help.
Old Feb 7, 2009 | 12:42 PM
Scott_Tucker's Avatar
Default Re: Balancer belt replacement done incorrectly
There shouldn't be any damage. He should just be able to re-time the balance shaft and it will be fine. Why didn't he do it when he noticed it and what qualifies him as an expert?
Old Feb 7, 2009 | 02:23 PM
ozvena's Avatar
Thanks!
He marked positions of all pulley's against the block of the engine, changed all 3 seals, pump and all the belts. He did not use the M6 bolt trick.
I suspect that the balancer belt slipped when it was inserted. I hope that the timing belt is properly installed.
I don't know why he did not noticed that something is wrong. He should have because I did the first 1/2 second after I turned the ignition key to start the car.
Old Feb 9, 2009 | 09:34 PM
acurtech6090's Avatar
yeah those balancer belts are a lil tricky. i did a 02 RL timing belt and the pulley rotated a complete circle and after i put it back together it had a vibrations under a light load. had to do that trick to make sure it aligned
Old Feb 17, 2009 | 07:45 PM
ozvena's Avatar
It was the shaped washer in the middle of the upper right motor mount. It was installed such that it was touching or almost touching the mount post.
Especially when the engine was cranked up, it banged and made noise.
It was properly rotated and the vibration is gone. Bummer!
Old Feb 17, 2009 | 09:48 PM
Evs-One's Avatar
Solbros Owns Me
every t-belt I do on Accords I just throw that bracket away. Used for assembly at the factory anyways and has nothing to do with the performance of the mounts.
WaryDriver
27
Oct 7, 2015 08:42 PM
Obd 1uan
Oct 27, 2006 09:36 PM
j87w
Aug 15, 2005 12:07 AM
fullracegsr
Apr 27, 2003 05:00 PM
gwaccord
Oct 1, 2002 04:04 PM
