Fuel Cut Early
Old Feb 7, 2009 | 04:45 AM
92egls's Avatar
Default Fuel Cut Early
I recently purchased a 92 civic cx from a friend of mine.. It has a ls swap well the car was showing the codes for the iacv, and the iat.. i got these fixed as it was a wiring problem.. but now a new problem has occured that i just noticed.. the car will hit fuel at 6200 rpms according to the tach in the car ::gauge cluster swapped from a ex::, my question is what can cause this as i have no more cel's...could the wire going from the distributor to the tach not getting a correct reading? or is it something else that wouldnt cause a cel...any help would be appreciated and thanks in advance for the help i get
Old Feb 7, 2009 | 04:46 AM
92egls's Avatar
Default Re: alot of searching
forgot to mention the car is running the 93 obd1 pr4 ecu...could this be causing the problem?
Old Feb 7, 2009 | 07:20 AM
92egls's Avatar
Default Re: Fuel Cut Early
bump
Old Feb 8, 2009 | 01:29 AM
92egls's Avatar
cel for code 14 (iacv) now...could a bad iacv be causing my dilemma?
g0tuj0ckin
Sep 25, 2008 08:01 PM
vtectuner2204
Oct 27, 2006 07:36 AM
SanSational
Jun 13, 2006 09:56 PM
verseone
Jun 14, 2004 03:15 PM
91civicEX
17
Sep 3, 2003 01:20 AM
