SAFE to REV 9K on b20V built???
Old Feb 6, 2009 | 08:22 PM
nengx07's Avatar
Default SAFE to REV 9K on b20V built???
i have a b20V with eagle rods, pistons, dual valve springs titanium retainer, itr cam chaft, sleeved block, head/block both ported n polish, and a bit more.. can i push it to 9K or should i just stick with 7.5k?? bc ive seen many b20v on youtube going 9K lol... WHAT IS HIGHEST n still SAFE i should go to??
Old Feb 6, 2009 | 08:26 PM
EJ8 GSR-T's Avatar
Default Re: SAFE to REV 9K on b20V built???
If its still making power up to that point, with springs and retainers i dont see why not...but theres obviously no reason to bring it that high if its not making more power.
Old Feb 6, 2009 | 08:27 PM
SOHC_4dr's Avatar
9K = BOOM!! (most likely lol) the rods you have are still stock stroke correct? you could rev a B20 that high, but you'll run the risk of pushing the piston through the wall. this is one downfall with the CR/vtec builds is that you cant rev em that high. if it was mine i wouldnt go any higher than 7,500
Old Feb 6, 2009 | 08:28 PM
nengx07's Avatar
alright.. just checking.. i want to try it once bc never went past 8k b4..
Old Feb 6, 2009 | 08:33 PM
raidacaipo's Avatar
stick to 8k... unless you have an aftermarket oil pan.. not enough oil while reving too high for a long time will = KABOOM!
Old Feb 6, 2009 | 08:34 PM
SOHC_4dr's Avatar
to put in better prospective, the B16B for instance has a stroke of 77.4 mm, bore 81 mm and is able to rev to 8,400 factory but can safely go much higher. the B20 has 89 mm stroke, bore 84 mm, a big diff and red lines at 6,300.
Old Feb 6, 2009 | 08:43 PM
nengx07's Avatar
dam never knew that lol... i guess ill stick with 8k.. 7.5k at 2nd-3rd gears rpm drops to 5.3k or so n vtec doesnt kick lol.. 8k makes it stays in vtec all the way
Old Feb 6, 2009 | 08:45 PM
SOHC_4dr's Avatar
8 it is then, just dont miss shift lol
Old Feb 6, 2009 | 09:05 PM
nengx07's Avatar
ill try not to miss shift lol..
Old Feb 6, 2009 | 09:36 PM
John M's Avatar
8k no higher
Old Feb 6, 2009 | 09:38 PM
nengx07's Avatar
ok ill stay 8K since alot of people referring it ^^
Old Feb 7, 2009 | 01:20 PM
JDM-TIM's Avatar
i don't know well here is my story i had a b20z2 block jdm b16 head ctr cams skunk2 pro mani with throttle body 70mm supertech valves springs and retainers, itr oil pump, i reved 8.5k daily drove the car for 45k miles no problem, but then i sold the car to this guy and he blew it the very next day! lol
I think you should be fine reving in to 8.5k!
Old Feb 7, 2009 | 05:23 PM
raidacaipo's Avatar
it blows up because lack of oil.. you need a better oil pan then the oem one.. like Moroso then you can rev higher than 8k..
Old Feb 7, 2009 | 05:33 PM
andoxviii's Avatar
Don't quote me, but I thought the B16B redlined at 9000rpm.
Old Feb 7, 2009 | 07:21 PM
SOHC_4dr's Avatar
no it didnt. the factory is 8,400. only the F20C in the S2000 did from factory
Old Feb 7, 2009 | 07:29 PM
ALLxMOTOR EG's Avatar
Vietnamese!
miss shift then ka-boom! lol
Old Feb 7, 2009 | 07:36 PM
andoxviii's Avatar
Oh ok.
I think this is why I thought it was 9k redline:
http://www.tigerjapanese.com/index.p...emart&Itemid=1
Old Feb 7, 2009 | 07:51 PM
SOHC_4dr's Avatar
tiger blows lol i hear to many bad things from em and they dont know their honda engine vary well.
see a factory CTR cluster here: http://img91.imageshack.us/img91/901...erkleinjh3.jpg
Old Feb 7, 2009 | 08:04 PM
andoxviii's Avatar
Yeah, they don't know Hondas well at all. They aren't the best company to communicate with, either...but I have had positive experiences with them and will be a returning customer.
Old Feb 7, 2009 | 08:13 PM
SOHC_4dr's Avatar
as long as they dont screw ya then stick with em
Old Feb 7, 2009 | 08:14 PM
lcsej1's Avatar
ticking bombbbb. i don't think there is a safe answer for that but if i were you id deff stay below 8k.
Old Feb 7, 2009 | 08:16 PM
andoxviii's Avatar
Yup. It's easier for me, too, since they're local. I can hand-pick
Old Feb 8, 2009 | 06:40 PM
nengx07's Avatar
i think 8k is fine and gives the next gear enough power to keep going fast.. 7.5k seems alido weak for me.. but never tried 9k and want to be on safer side.. about miss shifts i havent really miss yet once when racing.. hopefully new grs tranny can handle it lol
civicegsick
Dec 30, 2007 11:54 PM
champLSinteg
Aug 26, 2006 07:36 AM
175Shot4Door
Aug 22, 2006 07:44 PM
Westrock2000
25
Jun 12, 2003 06:00 PM
John
Nov 13, 2001 09:41 AM
