d16y8 to ob1 conversion help
hey i have just recently swap my EJ to a d16y8 and converted to a obd1
using a obd2-obd1 wire harness and i am also using a stock p28 ecu
for some reason my check engine light is on and the car seem like its darning alot of powers (the lights is flickering) the car also idle
any help would be appreciated
oh my bad
i was just playing bout the bumping
you know how it is when no one is there to help
anyways
how do i check for the code
my ej doesn;t have the plug like the eg where you can check it
anyways
ITS ONLY BEEN ONE MINUTE! you have to give it time for ppl to see, read, and reply.
and connect your OBD1 diagnostic reader to the OBD1 connection port. it should be on your driver side. under the leg panel
i believe there is a 2 pin connector by the ECU. or above the glove box. disconnect it and connect both with a paper clip.
your CEL will start blinking. and depending on the number of times it blinks and how it blinks(if it stays on long or a quick blink) it well tell you the code.
BUT i am not 100% sure of this 2pin location. i would search but the search is down
cardinalredeg
11
Aug 17, 2010 06:07 PM
94eg5squadMD
May 4, 2007 10:58 AM
