Help With Installing Axles
Old Aug 8, 2002 | 01:25 PM
HeikDiesel's Avatar
Default Help With Installing Axles
I can get the axle out of the transmission housing, but the bolt that keeps the axle in the hub, I cant break loose. Any help from you guys that have busted CV's and had to put in new axles? I un-did the upper control arm and the lower control arm so that there was more movement to pull it out. Anyone?
Old Aug 8, 2002 | 01:29 PM
kinesistech's Avatar
Default Re: Help With Installing Axles (PhatAcuraIntegra)
Air tools are best for that part. If you dont have any, you gonna need a breaker bar and a pipe for leverage. Put the suspension back together, and do it on the ground. You can try wedging a screwdriver or a punch in the rotor against the caliper.
Old Aug 8, 2002 | 01:30 PM
poison's Avatar
take a crow bar or big flat head screw driver and put it between the end of it and inside the tranny and pry it out and it will pop out.
civic92vx
Jun 29, 2010 09:55 AM
GraphiteMW
Mar 5, 2007 08:53 PM
kixcrx
14
Dec 8, 2006 10:03 AM
DarkBB4
Dec 21, 2005 04:16 AM
baked_beanz
Jun 1, 2005 04:02 PM
