ECU (Possible) trouble
Old Feb 6, 2009 | 07:33 AM
SOHCammed's Avatar
Default ECU (Possible) trouble
I bought my Ek last year during the winter, since then I've had some time to get used to my car. The more that I drive it, I believe the previous owner turbo'd it, and then denies he ever had a turbo on the car. Regardless, every time I hit 3k rpm I feel a loss of power in the car. It happens most of time after the car has had a chance to really warm up. I don't experience the problem first thing in the morning (when it's been cold). Any help or suggestions would be great?
Also, if it turns out that the ECU had been flashed, would getting a new(used) ecu fix the problem?
Old Feb 6, 2009 | 08:45 AM
z6hatchboy's Avatar
Default Re: ECU (Possible) trouble
well, you cant "flash or re-flash" a honda ecu (at least from 88-00) like a subaru or mitsu ecu. If it has been chipped, all you have to do is cut jumper j1 or j12 (i cant remember). Take the cover off your ecu, take a pic, and post and we can tell you if it has been or not. I might, try routine maintenance first and check the timing.
Old Feb 6, 2009 | 05:59 PM
SOHCammed's Avatar
Well, besides changing the spark plugs and checking the wires (they're good) I haven't had the timing checked or the water pump replaced. What else could I do. I can't think of any other routine maintenance that I could do.
Also, I gotta put the kids to bed so I'll post the pic in a bit.
Alright, I'll put up a pic tomorrow, the wife wants to watch some girly flick and I've got husband duties for tonight.
Old Feb 6, 2009 | 10:08 PM
trustdestruction's Avatar
Yea, it's J1. (Just clarifying)
Old Feb 7, 2009 | 11:31 AM
SOHCammed's Avatar
Icon6 Re: ECU (Possible) trouble
bump
Old Feb 7, 2009 | 11:40 AM
Originally Posted by SOHCammed
bump
did you open it up and see if it's chipped?
if it's chipped on one of those stupid eBay chips or something, that may be your problem.
Old Feb 7, 2009 | 04:58 PM
SOHCammed's Avatar
No, not yet. I had my in-laws come over after I had to go to work. So my saturday has kinda been shot. I was able to fix my receiver though! It was too far in instead of flush with the front of the dash.
Anyway, the camera was dead as well, so it should be all charged up now. I'll take a look at it later tonight in between my math homework. I'll need something to take my mind off of it for a while.
BTW, it's just a matter of pulling up the carpet on the right side, right?
Old Feb 7, 2009 | 05:08 PM
Mcdc2's Avatar
And taking off the cover if it has one
Old Feb 7, 2009 | 08:40 PM
Yea.
pull the carpet aside, unbolt the ECU from the kick panel (4 bolts), unplug the harnesses, and then open it up.
Old Feb 8, 2009 | 05:41 AM
SOHCammed's Avatar
here you go...when I took the side panel off there was only one screw holding the ecu in place. Further enforcing my theory that it was turbo'd and I was not told about it. Also, I have some pics of a mysterious steel braided line that goes to "nowhere." I have a feeling it's the oil return line.
Anyway, here's the ECU.
Old Feb 8, 2009 | 08:29 AM
ahhwhat?'s Avatar
what ecu is this???/
Old Feb 8, 2009 | 09:18 AM
SOHCammed's Avatar
It's out of my EK.
Old Feb 8, 2009 | 10:34 AM
wow... the guy who told you your ECU was "flashed" is a retard.
Old Feb 8, 2009 | 10:55 AM
SOHCammed's Avatar
Nobody told me my ECU was flashed. I've just been trying to troubleshoot this problem I have with car. I'm exhausting all my DIY options before I take it in to have someone look at it.
I just think it was turbo'd so I guess it's my mind playing tricks on me. If it wasn't turbo'd then it wasn't and I've just got a crazy steel braided line going down to the oil pan that connects to nothing, a car that seems like it starts to dump fuel right at 3000 rpm after it warms up, a new exhaust manifold gasket, and an ECU that wasn't put back or screwed in properly.
So, in my mind, that seems like all the pieces you would need to have a turbo connected to a car.
With that being said, what else could it be? I've never had the car timed, and I've never done it myself. A friend was telling me you don't need a light gun to time the d16y8. Is this true?
Old Feb 8, 2009 | 11:02 AM
your car isn't tuned, so that's not why it's "dump[ing] fuel right at 3000 rpm"
but yea, from your other problems, the car was obviously turbo'd
Old Feb 8, 2009 | 11:08 AM
SOHCammed's Avatar
So do you think just getting the car re-timed would help?Any other ideas would be great.
Old Feb 8, 2009 | 11:13 AM
having the ignition timing properly set will definitely make the car run better than if it's out of spec.
Old Feb 8, 2009 | 11:17 AM
SOHCammed's Avatar
So can I do this without a timing gun? I'd like to do it right now if I could.
Old Feb 8, 2009 | 11:18 AM
you need a timing light
Old Feb 8, 2009 | 11:23 AM
SOHCammed's Avatar
nuts...
Old Feb 8, 2009 | 11:24 AM
SOHCammed's Avatar
Well, thanks for your help. A lot! It's been appreciated. I'll get it timed here real soon.
Old Feb 15, 2009 | 06:34 PM
ahhwhat?'s Avatar
bro you dont need a timing gun.
Old Feb 15, 2009 | 06:35 PM
please explain
Old Feb 16, 2009 | 05:46 AM
SOHCammed's Avatar
Yeah, please explain...
nick91civicsi
Engine Management and Tuning
Oct 25, 2009 03:27 PM
§95HATCH§
May 16, 2009 07:19 PM
hondacrxflyer
May 26, 2004 09:27 AM
wrXtian
Apr 13, 2003 04:29 PM
