Minty's new camera setup, thought i would share
Old Aug 8, 2002 | 12:35 PM
MintyDip's Avatar
Default Minty's new camera setup, thought i would share
The 2 spy cameras are setup to a vcr in the car. The camcorder is jsut a camcorder
Clips coming soon with in the next 2-3 weeks....
Expect a So Cal Canyon Run Vid
https://honda-tech.com/zerothread?id=244003
Old Aug 8, 2002 | 12:36 PM
jonas's Avatar
Default Re: Minty's new camera setup, thought i would share (MintyDip)
the one on your spoiler looks like the APC indiglo muffler
Old Aug 8, 2002 | 12:37 PM
Rob :190:'s Avatar
what happens when a pebble hits this at 90mph?
Old Aug 8, 2002 | 12:43 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: Minty's new camera setup, thought i would share ( Rob)
haha- you will have about a sec of good footage- then nada.
later
matt
Old Aug 8, 2002 | 12:48 PM
Malice's Avatar
New User
were do u get that stuff?! prices?
Old Aug 8, 2002 | 12:54 PM
98TypeR's Avatar
Default Re: Minty's new camera setup, thought i would share (MaliceGSR)
you should put some kinda lexan infront of that front camera or you will get rocks and bugs
Old Aug 8, 2002 | 01:00 PM
yoshi234's Avatar
I shoot brides
how is the vibration ?
Old Aug 8, 2002 | 01:03 PM
Dave-ROR's Avatar
Default Re: Minty's new camera setup, thought i would share (98TypeR)
Put a wide angle lens adapter on it.. cool effect and a LITTLE protection.
Old Aug 8, 2002 | 01:06 PM
TypeR 599's Avatar
soo nice...
Old Aug 8, 2002 | 01:07 PM
zer0zer0 TypeR's Avatar
Default Re: Minty's new camera setup, thought i would share (TypeR 599)
that isht is off the hook!
Old Aug 8, 2002 | 01:14 PM
MintyDip's Avatar
There is a protective cap on the lens. It can be unscrewed and replaced if dmg
Waiting for my GF to return my power inverter so i can power these bad boys and make some vids
Reguarding vibrating. I had a previous setup very similar to this and it didnt vibrate, but the camera was the size of a dime.....
I need to desgin somethign that will keep the front camera from moving...
Teh rear is super stable
Old Aug 8, 2002 | 01:16 PM
MintyDip's Avatar
oh btw, No drilling was involved
Everything was done using holes that were already there
The rear was screwed into the spoilers brake light screws
Rob :190:'s Avatar
some hardware store mesh in the bumper opening, with a hole for the camera to fit in?
Old Aug 8, 2002 | 01:24 PM
Jimmy L's Avatar
Default Re: Minty's new camera setup, thought i would share (C5_ALLMOTOR)
How do you handle the feed from mutiple cameras, can you record both at once or do you have to switch between them?
Old Aug 8, 2002 | 01:25 PM
Big Phat R's Avatar
What are you doing for audio?? I was running a lipstick cam externally to my Sony Mini-DV cam - but the audio didn't work.
Do tell......
Old Aug 8, 2002 | 01:32 PM
slowassR's Avatar
Default Re: Minty's new camera setup, thought i would share (Big Phat R)
Wow! Thats so tight ..I really would like to do the same!
Old Aug 8, 2002 | 01:38 PM
MintyDip's Avatar
Default Re: Minty's new camera setup, thought i would share (Jimmy L)
i will have to switch between chns....
unless i get 2 vcrs
audio....im working on it.......... trying to find a mic that will work ......
does this exist: mic to rca audio????
Old Aug 8, 2002 | 01:41 PM
FredoSP's Avatar
Old Aug 8, 2002 | 02:37 PM
Dre_Chan's Avatar
Default Re: Minty's new camera setup, thought i would share (jonas)
true..
Old Aug 8, 2002 | 02:41 PM
MintyDip's Avatar
Default Re: Minty's new camera setup, thought i would share (Dre_Chan)
true..yah it does
those led are there for a reason...NIGHT VISION!
When im not using it on the car, it is my car security. I have the camera mounted on my house and pointed at my car from night to day. The video is recorded on to my computer using my tv tuner on the comp.
Good way to see what goes on around the car
[Modified by MintyDip, 3:42 PM 8/8/2002]
Old Aug 8, 2002 | 02:45 PM
uNF$@#!'s Avatar
actually i've seen a camera/camcorder mount made to bolt right into the license plate mount points
Old Aug 8, 2002 | 03:09 PM
canuck-mx6's Avatar
Lol, he said GF, Power inverter and vibrate all in the same reply......
Does you GF use the power inverter to power her vibrator
.....sorry, just couldn't resist
Old Aug 8, 2002 | 03:22 PM
MintyDip's Avatar
Default Re: Minty's new camera setup, thought i would share (canuck-mx6)
LMFAO hahahhahahahahahha
Old Aug 8, 2002 | 05:00 PM
Grandprix's Avatar
Where did you buy the cameras? Prices?
Thanks
Old Aug 12, 2002 | 02:05 PM
MintyDip's Avatar
Default Re: Minty's new camera setup, thought i would share (Grandprix)
Front problem solved
Solution: plexy glass covering useing the plate holes
NEWS: Side camera might be up as well Just need to make the bracket. I have the desgin
gonna bolt onto the side skirts and be protected by plexy glass as well
Picutres comign soon
