civic wheel wobble
Old Feb 5, 2009 | 03:02 PM
shuuttup's Avatar
Default civic wheel wobble
my civic driver side wheel just started to wobble and i have no idea wats wrong it have new alxes all wheel are tight but wheni take off it jurk to the left untill i hit 60mph+ but wheni let the gas go it still wobble can someone please help me out
thanks
Old Feb 5, 2009 | 03:17 PM
1992Si's Avatar
Default Re: civic wheel wobble
Could be any number of things. Do you plan too fix it yourself or take it to a shop and have them fix it ?
I would look at the ball joints first, tie rod ends, then lower control arms. Could be a bad wheel bearing.
Old Feb 5, 2009 | 04:57 PM
nengx07's Avatar
yup could be all those bc mines has same problem n those things are broken/bad
Old Feb 5, 2009 | 05:38 PM
mattison187's Avatar
is your wheel out of balance? thats another possibility..
Old Feb 6, 2009 | 06:52 PM
JDM-TIM's Avatar
i have the same problem and i was wondering how long can i drive like that? i dont wanna get a towing and tow my car to the shop and was wondering if i can drive it there its like 12 miles away or so.
Old Feb 6, 2009 | 07:06 PM
z6hatchboy's Avatar
wobble the wheel and get someone to hold the brake, if it goes away then its the wheel bearing. If not it could be the tie-rod. If you cant even wobble it with it in the air then it could be out of balance
Old Feb 6, 2009 | 07:41 PM
nengx07's Avatar
you should be able to drive it to the shop especially if it just started.. mines been liek that for 3 months n im still driving lol.. the tie-rod is more dangerous tho.. get it fix.. wheeling barring is just annoying but is still drivable
Old Feb 6, 2009 | 08:28 PM
starion88esir's Avatar
Grab on to the wheel while the car is on the ground. Try to move it diagnally back and forth (like you were going to make it go left then right) does it sound like the wheel is not bolted down? If so, it's your tie rod (something I desperately need to replace on my car) If it doesn't lift the front off the ground and try it again, if you feel it now, same problem, just not as bad. Mine is so bad you can do it on the ground and I get a few mm of play and the clacking. While you have it in the air place you hands at the top and bottom of the wheel/tire and try to wobble it forward and back. If there is play there then you have a bad ball joint or bad balljoints. Not as imperative as your tie rod and typically doesn't cause a vibration. Mine have been shot since I bought my car.
Unless you lost a weight I don't see the wheels being out of balance.
Old Feb 7, 2009 | 05:50 AM
itsmejto's Avatar
Geeeez, what a question to ask, get it fixed NOW or drive it till something falls off ... !!!!!!1
sicksiguy
10
Jun 3, 2016 01:46 AM
freshekhatch
Mar 8, 2008 05:12 PM
OnDaBottle
Nov 23, 2004 04:12 PM
90H22
Jan 28, 2003 09:47 AM
Mr. Vapor
Dec 5, 2002 05:29 PM
