ect switch!!!!
Old Feb 5, 2009 | 03:01 PM
lee0149's Avatar
Default ect switch!!!!
okay i broke my oem coolant switch and bought a switch from autozone. now my car is going pass the middle line. and suggestion?
Old Feb 5, 2009 | 03:43 PM
lee0149's Avatar
Default Re: ect switch!!!!
tt
Old Feb 5, 2009 | 04:15 PM
lee0149's Avatar
anyone?
Old Feb 5, 2009 | 04:18 PM
rx7kidd13's Avatar
might have a air pocket in the block purge all the air out
Old Feb 5, 2009 | 04:20 PM
lee0149's Avatar
how do i do that? open the radiator and squeeze the hoses?
Old Feb 5, 2009 | 04:26 PM
Former User's Avatar
Check the coolant level in the radiator and reservoir. Top off if necessary. As mentioned, also bleed the cooling system. 5th generation Civics have a bleeder bolt, whereas 6th generation do not. In the latter case, loosen the radiator cap, turn the heater lever to MAX heat on the dash, and let the engine idle until the radiator fan turns ON twice. Top off again when done, and then tighten the radiator cap.
gorpobr
May 1, 2008 06:35 PM
Twistedframe
May 24, 2007 08:26 AM
HamiltonRex
Jul 16, 2006 07:40 PM
Lavisracing
May 25, 2005 07:02 PM
intekragsr
Feb 27, 2003 02:14 PM
