Distributor problem!! need some advice!!
Old Feb 5, 2009 | 01:13 PM
b20vtech's Avatar
Default Distributor problem!! need some advice!!
ok i was out having fun with my car doing burn outs, all of a sudden my rpm just drops and motor dies, try starting it, motor just cranks but doesn't fire. Checked for spark and there was none, so i knew it had to be the distributor coil. Took out the dead coil and replaced it with a new but used one and it started right up! Was happy, normally droved it around the block came to a stop light and guess what?? RPM just dropped to 0 and motor just died out again!! So now im using a friends Distributor and it's working fine! Could this be something with the Distributor itself? cause it just fryed 2 freaking Coils!!
Old Feb 5, 2009 | 01:20 PM
teamworxek9's Avatar
Default Re: Distributor problem!! need some advice!!
It sounds like your ignitor inside the dizzy.
Former User's Avatar
In addition to replacing the coil, you should also replace the cap, rotor, plug wires, and plugs. The coil will blow if it cannot find ground through these downstream components of the ignition system.
Old Feb 5, 2009 | 01:32 PM
b20vtech's Avatar
doesn't that just messes only with the rpm and not cost the engine to die like how it did?
Old Feb 5, 2009 | 01:33 PM
b20vtech's Avatar
so this could mean that the distributor is still good but just the components are bad?
Old Feb 5, 2009 | 02:04 PM
Mine went in my old da and it happened the same way just died when i was driving wouldnt start till i replaced it.
Old Feb 5, 2009 | 02:49 PM
Yes
Old Feb 5, 2009 | 03:13 PM
1992Si's Avatar
If you plan to keep the car, buy a rebuilt dizzy. Trust me it's cheaper in the long run and less headaches in the coming month's.
Old Feb 5, 2009 | 03:19 PM
b20vtech's Avatar
where can i find a rebuilt dizzy?
Old Feb 5, 2009 | 04:00 PM
1992Si's Avatar
Any auto parts store should have them.
Here's one link
http://shop.advanceautoparts.com/Pro...pe=218&PTSet=A
that's for a
1996 ACURA INTEGRA GSR L4 1.8 Liter FI
I'm sure you can take it from here...
Old Feb 5, 2009 | 04:13 PM
whiteej8coupe's Avatar
get it checked first
and might as well check the battery too
it's $15 at pepboys
so do that and if it's not that then i'd probably check the alternator
Old Feb 5, 2009 | 04:21 PM
If the dizzy has more than 150k miles on it, replacing it with a rebuilt one makes good sense. Nonetheless, if the coil has been blowing due to bad plug wires or plugs, the coil in the rebuilt distributor is just going to blow again.
Old Feb 5, 2009 | 07:44 PM
b20vtech's Avatar
I don't think the plugs or plug wires got anything to do with it, cause im using the same plugs and wires with a buddys distributor and it's fine! been smashing on my car without a problem now.
Old Feb 5, 2009 | 07:49 PM
That's a good point.
Old Feb 6, 2009 | 04:20 PM
b20vtech's Avatar
bump
KiD Fr0m Da 516
Jul 28, 2023 11:30 PM
AndyD
Dec 22, 2014 03:13 PM
B16Turtle
May 28, 2009 01:03 PM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
HoNdAmAn29
Sep 4, 2004 08:49 AM
