Problem and engine questions
Old Feb 5, 2009 | 11:54 AM
paowa's Avatar
Icon2 Problem and engine questions
Recently i posted about the timing belt, but i also want to make sure its the timing belt. I believe the belt is missing a tooth or two, but i also realize when i crank the ignition, the belt only vibrates and the camgear hardly move or didn't move at all. Any feedback on what's going on? it seem's like the camgear don't attemp to spin, or is it because the belt is done? any suggestion would help! thanks. and if i do get it replace, any price estimation?
Old Feb 5, 2009 | 12:06 PM
93egSLEEPER's Avatar
Default Re: Problem and engine questions
sounds like your engine is locked up.
a bad timing belt typically doesnt make it so the car wont turn over. if it was missing a tooth or two that woudnt necessarily make it not start either... more then 2 teeth are in contact with the cam gear at any given point.
Old Feb 5, 2009 | 12:09 PM
paowa's Avatar
can you explain engine locked? define pls =(
Old Feb 5, 2009 | 12:15 PM
Nbboy7's Avatar
i had the same problem but it was my alternator locked up
Old Feb 5, 2009 | 12:16 PM
keving85's Avatar
if your crank is turning over and your cams are not then you have a problem..... i have seen a belt loose a few teeth and then strip all the teeth down at the crank gear.... causing it to just spin around the belt....
kev
Old Feb 5, 2009 | 12:24 PM
paowa's Avatar
any resource or any way of knowing the actual problem? is there any test or diagnostics that i can do to check? So, if the cams are not moving, does that mean the engine is done? Let me know please thanks!
Old Feb 5, 2009 | 01:35 PM
keving85's Avatar
if the crank is turning and the cams are not then yeah the motor is....... but if your crank is not turning then either you have a starter problem... locked up motor.... or possible A/C, Alternator, or power steering pump locked up...... but if your missing teeth off of your timing belt my bet is there is something wrong with the motor itself..
kev
Old Feb 6, 2009 | 12:16 PM
paowa's Avatar
Some people have the same incident. I was wondering if there is going to be a lot of damage to the engine. People said at a lower speed, or not accelerating at all might prevent any engine damage. But the i'll give the update on it this weekend. Any other suggestion? Could it still be saved? i've been researching and there could be a lot of alternative resource on what could be the problem. if the piston does hit the valve, do i just need to replace the head?
Old Feb 8, 2009 | 04:20 PM
paowa's Avatar
put a new timing on and also a new water pump. everything dead top center. I cranked the ignition and the car doesn't start. Sounds like its not firing up. The cams turn and everything else seems to be in place. everything is good, but the car still won't start. I'm guessing its the valve, but not sure. Any suggestion?
todenbach
Jan 26, 2014 12:26 AM
JDMtype Eg6
Feb 18, 2007 05:45 AM
Ziggymidget5
Apr 20, 2005 03:23 PM
1SlowSi
Feb 6, 2005 04:39 PM
batman_22
Oct 30, 2002 03:41 AM
