Help Me Decide a LS-T Setup
Ok, So i possibly planning a turbo setup for my LS
I have a 1995 LS All stock.
My goal is to get up around 250-300 HP.
I've been reading and i guess i can get 250 with stock block if i can keep it 10PSI or Below.
So what Turbo.. ETC should i get to reach this goal..
Thanks for your suggestions.
From: New York in the summer, South Carolina in the winter
For 250whp, from as far as I can tell, a T3 60 trim like that found on evans-tuning for 490 bucks is the best bet- Probably what I am going to run on my LS
Terrance.
50 or 57 trim will be needed to get you up toward 300whp with the efficiency of a stock ls motor.
2 years ago i ran a 57 trim with a .48 exhaust on a stock ls motor at 10 psi. it was awesome. full boost around 3800rpms and it pulled soo smooth to 7000. same turbo on another ls motor i had made 240/205tq on 10 psi
good luck!
