Help Me Decide a LS-T Setup
Old Feb 5, 2009 | 11:09 AM
DC206R's Avatar
Default Help Me Decide a LS-T Setup
Ok, So i possibly planning a turbo setup for my LS
I have a 1995 LS All stock.
My goal is to get up around 250-300 HP.
I've been reading and i guess i can get 250 with stock block if i can keep it 10PSI or Below.
So what Turbo.. ETC should i get to reach this goal..
Thanks for your suggestions.
Old Feb 5, 2009 | 12:11 PM
adam00's Avatar
Default Re: Help Me Decide a LS-T Setup
https://honda-tech.com/forums/forced-induction-16/lst-ls-t-turbo-b18a-b18b-setups-1323059/
Old Feb 5, 2009 | 12:29 PM
Ls_dx's Avatar
be sure to get a nice tune up (ectune) good luck!
Old Feb 7, 2009 | 01:35 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
For 250whp, from as far as I can tell, a T3 60 trim like that found on evans-tuning for 490 bucks is the best bet- Probably what I am going to run on my LS
Old Feb 7, 2009 | 03:39 PM
Silva Bullit DC4's Avatar
A Garrett t3/t04e 50 trim .63 a/r will get you that 250 to 300 whp with a lot better powerband than that 60 trim. I used to hit full boost at 3800 rpm with my old setup, which had a 50 trim Borg Warner.
Terrance.
Old Feb 8, 2009 | 05:47 AM
blackeg's Avatar
50 or 57 trim will be needed to get you up toward 300whp with the efficiency of a stock ls motor.
2 years ago i ran a 57 trim with a .48 exhaust on a stock ls motor at 10 psi. it was awesome. full boost around 3800rpms and it pulled soo smooth to 7000. same turbo on another ls motor i had made 240/205tq on 10 psi
bb6guy
Nov 24, 2009 05:47 AM
LSej1
May 1, 2008 02:40 PM
THIZZ_BOSS
Jun 13, 2006 09:07 PM
thaiphob
Dec 28, 2003 07:28 PM
pip9
Dec 18, 2003 03:59 PM
