Stock GSR Injector + Fuel Pump?
it can only be done if you are using an FMU and inline fuel pump, which no one on this site is going to recommend.
stock injectors are 240cc and close to maxed out in stock form. even N/A guys upgrade injectors when they start making any type of power. bare minimum you will need 450cc injectors.
also a straight t4 is too big for your application and probably inefficient at only 6psi. keep researching
you get dumb answers becasue that question is way to broad. if you want us to help with a turbo choice you need to give a detailed description of your setup, what whp you are trying to acheive and what you use the car for (drag, road race, daily driver). even after all the you are going to get multiple answers so at the end of the day its a personal choice
injectors will also be determined by whp so once you give us more info then we can help.
Have you done any type of research before you asked? I know the search is down but I know SOMEWHERE in the faq there must have been something about this.
Stock injectors and fuel pump wont work, pick a turbo and power goal and that will determine what you will need...
yusoslo
Mar 23, 2004 01:54 PM
