Oil cooler oil leak
Old Feb 4, 2009 | 03:32 PM
marcus81184's Avatar
Default Oil cooler oil leak
99 lude. I'm assuming gasket on my oil cooler must be blown. Right behind the filter, and sensor. Removed the bolt behind filter. What do I do next to remove the oil cooler?
Old Feb 4, 2009 | 09:56 PM
TheJGB3's Avatar
Default Re: Oil cooler oil leak
You need a 30MM socket to remove the bolt that the oil filter spins onto. After removing this I believe the cooler comes off.
The oil cooler o ring is part#
91316-PT6-003 O-RING (62.4X3.1) $2.45 list
Old Feb 5, 2009 | 09:03 AM
I assume it just prys off. Thanks.
Old Feb 5, 2009 | 09:25 AM
Ring was broken. What a terrible spot to have an oil filter.
chiaxi2002
Apr 9, 2010 08:56 PM
holmesnmanny
Dec 10, 2009 03:14 AM
J.nguyen
Oct 14, 2006 06:04 AM
El pimp chulo
Aug 5, 2006 05:51 PM
LOWLIFEHATCH
14
Aug 27, 2002 02:45 AM
