Bent Valve symptoms??
Old Aug 8, 2002 | 10:23 AM
LshatchTurbo's Avatar
New User
Default Bent Valve symptoms??
What are some symptoms of having bent valves? Thanks
Old Aug 8, 2002 | 10:44 AM
riceboy's Avatar
Default Re: Bent Valve symptoms?? (lshatchturbo)
the car idles like a 302
Old Aug 8, 2002 | 12:29 PM
New User
Default Re: Bent Valve symptoms?? (riceboy)
thanks, anything else comes to mind?
kinesistech's Avatar
Shitty idle, shitty power, shitty compression test figures.
Old Aug 8, 2002 | 01:50 PM
Chiovnidca's Avatar
Valve noise.
Old Aug 8, 2002 | 05:35 PM
New User
Default Re: Bent Valve symptoms?? (kinesistech)
The symptoms you guys describe, could this be also a result of valves that need adjustment?
Old Aug 8, 2002 | 05:39 PM
spencer00si's Avatar
you should see a little smoke coming out of the exhaust. i would try to get the valve adjusted 1st before going through installing new ones.
Old Aug 8, 2002 | 06:02 PM
New User
Default Re: Bent Valve symptoms?? (spencer00si)
Well hopefully I dont have a bent valve considering i dont have many of the symptoms you guys describe maybe except power loss. What happened was there was a bad leak in my windshield. I had about a inch of standing water in my car next to the ECU. I pulled out the LS ECU and let it dry off but I really had to get to class and threw in my DX ECU. Everything was all good. Then I decided to go wide open throttle, and for the first time I saw A/F gauge go lean bad. I checked my plugs they were toast, and my distributor rotor looked fucked as well. I replace them, but I still have a bog from 3000-3500 rpms.
Old Aug 8, 2002 | 06:17 PM
uselesscrown's Avatar
Did you check your coils? Especially if your engine is a Vtec and the DX brain wasn't, they might be damaged. The Vtec's put in different voltage at different times than the non-Vtec's so you might have sent too few or too much. Also, check the wiring, you may have shorted the Vtec wiring out since I don't think the DX was a Vtec was it?
Old Aug 8, 2002 | 06:53 PM
New User
Default Re: Bent Valve symptoms?? (uselesscrown)
I am using a external blaster coil from MSD, and I have a OBD-1 LS motor, so no vtec. Is there a way i can test the coil with my multimeter?
Old Aug 9, 2002 | 01:48 AM
PyroVTEC's Avatar
New User
Yes you can check the resistance w/ a multimeter. Test both primary and secondary winding coils. Since the secondary coil is a higher resistance (20K ohms+), you might find a digital multimeter more useful than an analog one though.
.RJ
10
Apr 10, 2006 11:19 AM
JBBNJ609
Dec 13, 2003 10:56 AM
typesguy
Aug 7, 2003 11:00 AM
HX_Guy
Nov 7, 2001 08:39 AM
