Oil light.
Old Feb 4, 2009 | 02:25 PM
5.56's Avatar
Icon6 Oil light.
I've got a b16a2 in my 95 integra ls. This morning when I turned on the car, the oil light came on, but this time it didint turn off. It stayed on, flickered a few times and then started blinking. The weather around here is below freezing in the mornings. I'm using 10w30 oil. What could my problem be?
Old Feb 4, 2009 | 02:45 PM
808DA's Avatar
Default Re: Oil light.
did you check to see if your car had oil? did you park on a steep hill/driveway?
Old Feb 4, 2009 | 03:09 PM
kranky81's Avatar
check ypour oil, it might be low, how many miles on the car?
Old Feb 4, 2009 | 03:13 PM
stocker2shocker91's Avatar
I requested a short story for a title.
even so there should still be enough oil in it to have the light not stay on.....i would say your pretty low check it out
Old Feb 4, 2009 | 03:39 PM
5.56's Avatar
Thanks for the answers guys, my driveway is on a bit of a slant. But my oil is fine. I just drove it about a 1/2 hour ago and no problems. Only thing I notice is that the oil light comes on when I start it after its been sitting overnight or for a few hours.. when its cold.. The oil light comes on, and stays on for about 10 seconds. Then shuts off and comes back on for about a second and turns off completely. Is this normal. The motor has about 70k miles on it since the rebuild. Sombody told me it could be my oil pressure switch. How can I check whether this is true? Thanks, anything would help!
Old Feb 4, 2009 | 09:11 PM
b20vtek's Avatar
it might be your oil pump loosing pressure. check your oil pressure, i live in mass the temp is very low too and i don't have that problem
Old Feb 5, 2009 | 09:16 AM
5.56's Avatar
Thanks!
Old Feb 5, 2009 | 10:50 AM
aemintgsr's Avatar
The oil light usually means that your pressure when it hits the sending unit is 5-10 psi which is LOW!!
One way of checking is to turn on the car and with the light on disconnect the cable that goes to the sending unit and if it is still on that means that the cable is grounded.
A quick way is to turn the car on an open the oil cap to see if oil is flowing around the head that would mean there is pressure.
Old Feb 5, 2009 | 01:27 PM
5.56's Avatar
Thanks! Helpful info!
Old Feb 7, 2009 | 12:00 PM
Tegraracer90's Avatar
this happend to me....the wire ground out sometimes i pushed the clutch in (which is why it was on when it started) and then it would blink every time i shifted....it drove me crazy...
csambitions
Mar 20, 2006 09:42 AM
mugenhatchie
Jan 30, 2006 06:50 PM
1 Cam Wonder
44
Nov 23, 2004 08:18 AM
1hotintegra
Dec 15, 2002 08:00 PM
chameleon
Feb 21, 2002 08:54 PM
