5th Gen Rear Lower Ball Joint
Old Feb 4, 2009 | 02:14 PM
brotherparker's Avatar
Default 5th Gen Rear Lower Ball Joint
I'm trying to find rear lower ball joints fro my 97' lude. So far all I have found is the whole knuckle from Honda. Is there any alternatives? There doesn't seem to be any aftermarket replacement.
Old Feb 4, 2009 | 03:54 PM
Kronn 98SH's Avatar
Default Re: 5th Gen Rear Lower Ball Joint
http://www.hondaautomotiveparts.com/...A5MT&catcgry5=
Click that and go from there.
Old Feb 4, 2009 | 04:04 PM
Thanks for the reply. Unfortunately this site doesnt list the ball joint separate from the knuckle. I am wondering if the ball joint from the older Preludes or another Honda will fit?
Old Feb 4, 2009 | 04:31 PM
gstrudler's Avatar
I believe the adjustable ball joints from SPC or Ingalls should work.
Old Feb 4, 2009 | 06:13 PM
pprowler6's Avatar
it would work in the upper control arm but not the lower...i have looked before from rear lowers and came up empty. Although i heard rumors that the legend front lowers would work. im not positive though
Old Feb 4, 2009 | 08:31 PM
gstrudler's Avatar
my bad, forgot we were talking lowers.
Old Feb 4, 2009 | 08:56 PM
TheJGB3's Avatar
On a 5th gen lude to replace the rear lower ball joint (base and SH) you have to purchase an entire knuckle. This is the only way Honda sells it. For the front axle the SH has two lower ball joints that are replacable, but the base model requires the knuckle to get a new lower ball joint.You never mentioned if you had a Base or SH, but it looks like on the rear they are BOTH THE SAME PART#
I found a boneyard that has both rear knuckles for you
The knuckle/spindle are off of a '97 base model and the price is $75ea.
They probably will come with the hub/bearing and the brake dustshield still installed
Rt. 43 Auto Parts, Inc. in Carrollton, OH 1-330-627-7700 Stock#PRE6
http://www.rt43autoparts.com/
2016 Canton Rd.
Carrollton, OH 44615
(330) 627-7700
Fax: (330) 627-1919
Old Feb 9, 2009 | 01:49 PM
I was hoping to find an alternative. I saw some people saying lower front ball joints from the Acura Legend fit but there isnt much info about it. I guess I'll have to purchase the whole knuckle. I also saw a post that front one from a 2004 Accord work. Can anyone confirm either of these.
Old Feb 21, 2009 | 08:42 AM
I am Canada so ordering used parts from the States will probably not be worth it. Priced the knuckles at Honda. $300 a piece. I guess I will go with them. Thanks
ross2004
Jun 13, 2017 10:05 AM
pprowler6
Mar 10, 2012 11:14 AM
SteveoBA8
May 3, 2010 05:15 PM
brotherparker
Mar 5, 2009 05:13 PM
wstef
Mar 7, 2004 11:58 PM
