car idles way high
Old Feb 4, 2009 | 12:44 PM
-=ZAK=-'s Avatar
Default car idles way high
my car isles at like 2 grand when its cold until it warms up anyone know why. iv cleaned the iacv and just got a new dizzy coil. i dont have an o2 sensor tho. but i dont think that would cause it. anyways after it warms up it goes back to the normal idle? any help??
Old Feb 4, 2009 | 01:40 PM
daytona-eg3's Avatar
Default Re: car idles way high
is it over fueling????
Old Feb 4, 2009 | 03:25 PM
-=ZAK=-'s Avatar
nah its running fairly lean. or well smells like it anyways
Old Feb 4, 2009 | 03:29 PM
85_305's Avatar
check for vacuum leaks.. very likely a line cracked. Make sure pcv and no other lines are clogged (like ones going to your intake).
Try resetting your battery.
As a last resort, adjust the idle adjustment screw
Old Feb 4, 2009 | 03:34 PM
andoxviii's Avatar
My car does this everytime, but its freezing over here. I thought the computer makes the engine idle high to warm up quicker.
Old Feb 4, 2009 | 03:36 PM
85_305's Avatar
The cold idle is like 1600rpm's.. 2000rpm's is kinda high I think.
Old Feb 4, 2009 | 03:39 PM
Pothole987's Avatar
mine idles at 1500 during the summer and 2000 is about mine does when it sees the cold. Put AN 02 in that though, the computer problaly needs that for a reading.
Old Feb 4, 2009 | 03:50 PM
-=ZAK=-'s Avatar
funny stuff with the idle screw and all seein mine is to the point were my throttle body wants to stick.
Old Feb 4, 2009 | 03:53 PM
ShinyNewPenny's Avatar
My civic idles at 3k when it's cold, at about 700 when it's warm. O.o
I just sorta got used to it, even tho I know it shouldn't do that. haha
Old Feb 4, 2009 | 03:56 PM
85_305's Avatar
Mine was doing this too; the throttle valve seemed to stick to the actual throttle body.
Grab some STP throttle body and intake cleaner, and clean the hell out of it. You can take the TB off (preffered method), or do it with it on. Do this w/ the car off at first, and make sure to really scrub that cleaner in. There will be a lot of carbon/varnish. Then, turn the car on and go over the same steps again (obviously w/ the tb reattached). Take the hose off that goes from the valve cover to the inake, and spray the hell outta it.. could be clogged.
Old Feb 4, 2009 | 04:04 PM
-=ZAK=-'s Avatar
i said that with hints of sarcasm "as in the idle screw is screwed out so far its hardly touching the throttle body and if its not touching the throttle body will stick"
Old Feb 4, 2009 | 04:08 PM
85_305's Avatar
Oh I see :think:
ih8bikes
Mar 26, 2008 06:39 AM
virusiidx
Jan 18, 2005 07:21 AM
jokr78
Dec 15, 2004 01:47 PM
ITSTOCK
Oct 28, 2004 12:03 PM
Ri5e
Oct 9, 2004 07:41 AM
