Regulator on fuel rail
Old Feb 4, 2009 | 10:53 AM
rip94delsol's Avatar
Default Regulator on fuel rail
Okay heres the deal, I have a golden eagle fuel rail and a aeromotive fuel pressure regulator.
My problem is that if I mounted the regulator directly onto the rail with the correct aluminum fitting does that pose a problem for breaking off? I've seen many ppl mount it this was but when I went to the Earl's store they recommended me not to mount it this way cause they said "for sure it will break".
Has anyone have their fitting break due to mounting it like this? If so what type of fitting did you use? aluminum or steel.
thanks
Old Feb 4, 2009 | 11:15 AM
scmil95eg's Avatar
Default Re: Regulator on fuel rail
Lots of people do it and get away with it - but, fittings are not designed to support weight, add engine vibration and wheel hop... it could easily break off. They told you the safest thing so you can't come back to them and say, "well you said I should be ok, and it broke so it's your fault and you suck." lol
ThE HeLLRaZoR
Feb 15, 2012 11:02 AM
kte324
Apr 2, 2011 07:00 AM
Tigfab
Jul 21, 2007 03:57 PM
Prelude_2_NV
Jan 28, 2006 02:37 AM
skunkwhat
Jul 30, 2004 04:02 PM
