Where to mount Fuel Pressure Regulator?
Old Mar 11, 2010 | 05:23 PM
kte324's Avatar
Default Where to mount Fuel Pressure Regulator?
I have a fuel lab regulator with a aem rail. It would be easier on me to mount it on the end of the rail, as in have a coupler joining them two. Would the regulator get loose over time? Or should I just mount it on the body/firewall.
Old Mar 11, 2010 | 06:14 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Where to mount Fuel Pressure Regulator?
i wasnever a fan of hanging that much metal off of the end of the rail but thats my 2 cents.
i put my aeromotive reg on the firewall.
Old Mar 11, 2010 | 06:29 PM
Turbo-LS's Avatar
ive run an aeromotive on both the end or the rail and on the firewall and neither were a problem. its not like it weighs a ton. i personally would do the rail and make a bracket to thold the regulator even though its onthe rail for added safety and that will make sure it does get loose and or break off. i made a simple brace for mine when i ran it that way.
Old Mar 11, 2010 | 07:52 PM
da_dude's Avatar
I ran my aeromotive fpr off at the end of the rail myself too. Not sure which one you have but fuel lab came out with a smaller version.
Old Mar 12, 2010 | 07:07 AM
kte324's Avatar
I have the regular version.
I have the fittings to either mount it on the rail or the firewall. I think I might try the rail and if it gives me any problems I will just mount it on the firewall.
Old Mar 12, 2010 | 08:12 AM
tuhboek's Avatar
IMO id go with the firewall just to reduce vibration that the motor may produces and absorb causing a less acuret reading/delivery possibly.
Old Apr 2, 2011 | 06:17 AM
BrowNKiD's Avatar
Is there any set backs to mounting it on the fuel rail... I mean performance wise?
Old Apr 2, 2011 | 06:56 AM
portenio78's Avatar
The fuelab regulator on the end of the rail is fine. Just make sure you use the steel fitting to mount it.
Old Apr 2, 2011 | 07:00 AM
wantboost's Avatar
Who is Mr Robot?
no, it will regulate fuel pressure regardless of where you place it
and why the hell did you bump this thread from the grave?
ComeOnKip
Oct 18, 2009 08:53 AM
rip94delsol
Feb 4, 2009 11:15 AM
Tigfab
Jul 21, 2007 03:57 PM
sleepyhatch00
Sep 23, 2005 12:19 PM
skunkwhat
Jul 30, 2004 04:02 PM
