What do I need to swap in an LS/VTEC engine?
Old Feb 4, 2009 | 03:30 AM
chuy4021's Avatar
Default What do I need to swap in an LS/VTEC engine?
OK a buddy of mine has a 91 integra gs with a ls block and a jdm b16 head with vtec. I have a 93 ls integra with the stock engine wich is the b18a1 non vtec i was wondering what do i need to completely do the swap from my buddys engine.He has a wiring harness he will give me thats obd0 to obd1 but what else do i need for the full swap, come on honda tech i need you thx!!
Old Feb 4, 2009 | 03:34 AM
4g63powered's Avatar
Default Re: Need your guys help plz!!
Huh? Try some punctuation, maybe it will be easier to understand WTF you're asking.
Old Feb 4, 2009 | 03:40 AM
chuy4021's Avatar
my bad just that im tired and got off of work
Old Feb 4, 2009 | 04:49 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What do I need for LS/VTEC?
Try searching, specifically in the All Motor and Hybrid forums. There is tons and tons of info regarding LS/VTEC setups around here.
Old Feb 4, 2009 | 06:20 AM
neardon's Avatar
I'm a Jackass
Default Re: What do I need to swap in an LS/VTEC engine?
Dont cheap out on stuff, you want to build a strong motor. A tune is always good, or atleast a base map from someone elses tuned ls/v.
---Engine, LS/VTEC and CRVTEC---
https://honda-tech.com/forums/acura-integra-6/ls-vtec-hp-2207108/ - Good LS/VTEC discussion
https://honda-tech.com/zerothread?id=1676914 - LSVTEC Build (THANKS MADNESS)
https://honda-tech.com/zerothread?id=1812388 - LSVTEC Build price list (THANKS MADNESS)
https://honda-tech.com/zerothread?id=1119323 – A Few Good Links
https://honda-tech.com/zerothread?id=1082172 – A Few More Good Links
https://honda-tech.com/zerothread?id=1083788 – Break-In Period
https://honda-tech.com/zerothread?id=501372 – Reliability Issues
https://honda-tech.com/zerothread?id=720621 – Quarter Mile Times
https://honda-tech.com/zerothread?id=805408 – Using LS ECU
https://honda-tech.com/zerothread?id=1467903 - B20 NonVtec FAQ - (THANKS DRINTEGRA & BAMBAM)
https://honda-tech.com/zerothread/1767009 - B18C1 vs B16A Head flow chart (THANKS dohcMONSTER)
Old Feb 4, 2009 | 06:57 AM
Community Builder
I had to go back and read the OP, but the question was about swapping an already-assembled and apparently running LS/VTEC from an OBD0 car to an OBD1 car, not the actual LS/VTEC build process.
Old Feb 4, 2009 | 08:50 AM
chuy4021's Avatar
ok thx guys i really apreciate this very helpful!!
hon95civ
Jun 23, 2012 04:37 PM
nelsonb16
Sep 24, 2007 04:49 PM
dacaveman
Jul 18, 2003 05:31 PM
jumpmann23
14
Mar 25, 2003 01:41 PM
integra81
Oct 18, 2001 07:10 PM
