?'s for 450cc precision injectors
Old Feb 4, 2009 | 01:47 AM
da_ska's Avatar
Default ?'s for 450cc precision injectors
i was just wondering if i buy the 450cc precison injectors and install them on a my car will i need to modify anything besides installing a resistor box. its a b16a2 motor.mainly just a chipped p28 and stock manifold in 94 civic coupe the ex model.
Old Feb 4, 2009 | 01:56 AM
D16SiHatch's Avatar
Default Re: ?'s for 450cc precision injectors
you'll need to have ecu programmed so that it knows the injectors are larger than stock.
Old Feb 4, 2009 | 08:22 PM
da_ska's Avatar
oh okay thax.im going to look on that. but do you know if i need anything like for example larger clips for the larger injectors. or maybe new o rings because this harness came out of a d series motor
Old Feb 4, 2009 | 08:23 PM
trustdestruction's Avatar
you'll need OBD1 injector clips i believe
o-rings should be fine unless they're worn out
and if you get the high impedance ones, you don't need a resistor box
Old Feb 5, 2009 | 02:04 AM
da_ska's Avatar
thax trust.... im actually getting hold and peak injectors so i will too need resistor box.oh i c so you dont need bigger clips or different o rings. well i hope to buy those injectors and hopefully things fit to ease.thax
GT500FTW
Nov 29, 2012 03:10 PM
mortificationrock
Jun 10, 2007 09:05 PM
dave24
Aug 3, 2006 07:43 PM
eK9aT10pSi
Jul 24, 2005 09:56 PM
FMIDRC Racer
May 13, 2005 06:00 PM
