da speedo cable. supposed to be that short??
Old Feb 3, 2009 | 11:25 PM
royalrebel's Avatar
Default da speedo cable. supposed to be that short??
so im changing my speedo and disconnected all the electronic stuff and got down to the cable. it came out hard but eventually got it ..now on the re-assembly i can barely fit my hand to reconnect the speedo cable. is it supposed to be this short?? anybody else have problems with this too?? thanks all help is welcome
Old Feb 3, 2009 | 11:27 PM
hybrid1990crx's Avatar
Default Re: da speedo cable. supposed to be that short??
Yeah they are a bitch sometimes. What I do is I leave it disconnected from the trans so you can pull it farther into the interior to do the cluster then I pull it back through to hook it to the trans.
Old Feb 4, 2009 | 12:10 AM
seanbev24's Avatar
haha yep i hate dealing with that damn cable
Old Feb 4, 2009 | 09:07 AM
royalrebel's Avatar
yeah its a real pain.. my cel came on..anybody have any idea if its bcuz of this cable not being properly connected?
Old Feb 4, 2009 | 10:23 AM
HONDRETTI's Avatar
check your code. if your speedo is working, its something else.
Old Feb 4, 2009 | 10:54 AM
royalrebel's Avatar
the speedo cable is not plugged in...im guessing it should go away wen i plug it in correct?
Old Feb 4, 2009 | 11:20 AM
yeah when the speedo isn't working you throw a code 17 or something for the VSS.
Old Feb 5, 2009 | 12:23 PM
seanbev24's Avatar
also when you do plug it in, make sure it's seated all the way both on the cluster and the tranny. sometimes it will feel like it's in but it won't be fully seated and will throw your speedo out of whack.
and like hybrid1990crx said, i just disconnect it from the tranny first so i have a little more to work with behind the cluster.
GPC91
Sep 17, 2012 01:11 PM
dusterbd13
Oct 19, 2009 06:47 PM
jcrou
Dec 17, 2004 08:56 AM
PA MATT
Apr 6, 2004 07:40 PM
