compression test
well guys i did the compression test yesterday,b18b1 and i got this ####
195
180
180
170
my headgasket is bad and i will change it next week.my oil its milky, and white smoke from the exhaust. i also will change my head for a rebuild b18b1 head port and polish ferrea springs and retaines and 3 angle valve job.
what u guys think about this numbers will they change after i replace the headgasket?????i m going turbo soon
195
180
180
170
in the FAQ
is the following post it will help you educate yourself a little more about turbos.
http://beesandgoats.com/boostfaq/g2icturbo.html
would be nice if you help yourself with the FAQ post in order to know more about the b series
The numbers are ok. They're within spec as far as the difference between lowest and highest readings between cylinders go.
It's hard to tell how a new head and new gasket will affect the numbers unless you do a leakdown test. If you are losing compression from your gasket/valves/crack in head then your replacements will help. If you are losing compression through your rings, it's not gonna do much.
I would not have suspected a blown head gasket from those numbers. I'm guessing it's not breached immediately around any of the cylinders. Perhaps the HG breached just between an oil passage and the water jacket?
thanks and GL with the head swap. just remember to torque everything to spec and in the correct sequence and double check that you get that timing belt on right.
also, if that rebuilt head is milled, expect your compression readings to go up a bit just cuz of that.
SilkyJohnson
13
Feb 15, 2011 05:54 PM
turbosivtec
May 24, 2009 04:33 PM
humboldt_skim
May 31, 2008 08:18 AM
