front subframe is outa wack any way to whack it back?
Old Feb 3, 2009 | 07:25 PM
eklum's Avatar
Default front subframe is outa wack any way to whack it back?
my car was recently involved in accident and my front lca bent in the process and i tore the front subframe up a little bit , i need more expert advise as i havent had to tackle this subject before ,
i poped the lca out and everything kinda went back into place with the steering components the tie rod/steering rack works fine and is intact , i figure once i can get the axle out i can go to work on the area thats torn from the sub frame and hammer it back and eventually get nick to weld it back to the subframe and say **** it to the part thats tearing a little bit
as pictured.
if i can bend the lcas joint or whatever fork thing where it goes in i can get that shitty tac welds back to where they needa be weld that and not worry about the part where it bolts into the frame as much does any one have any input about what i just said cuz its just a idea haha
Old Feb 3, 2009 | 07:47 PM
hayabusa160's Avatar
Default Re: front subframe is outa wack any way to whack it back?
imo i would find a new one.
Old Feb 3, 2009 | 08:11 PM
eklum's Avatar
are they fairly easy to replace? just disconnect the rear motor mount( or take out motor/tranny completely ) disconnect the steering rack and unbolt the 4-6 how ever many bolts holding it up should be a cinch?
Old Feb 3, 2009 | 08:59 PM
mfef4dr's Avatar
replace it, and yes thats just about all you gotta do.
Old Feb 3, 2009 | 10:03 PM
eklum's Avatar
bah anyone know where i could go about buying one or how much pick and pul?
Old Feb 3, 2009 | 10:05 PM
mfef4dr's Avatar
where are you from? there easy to find here in my city
what kind of car is this? did i miss it some where posted?
EF sedan?
Old Feb 3, 2009 | 10:48 PM
eklum's Avatar
yeah its a ef sedan i live in the east bay if you could source one for me for a reasonable price ill swoop it off u if your able to find'm lmk!
Old Feb 5, 2009 | 07:15 PM
j_bizach's Avatar
ahh if you popped spot welds like that you may wanna have that put on a frame rack cause id be willing to bet something other than just the subframe has been tweaked. What happened exactly
Old Feb 5, 2009 | 11:41 PM
mfef4dr's Avatar
damn your right, I didn't even see those spot welds.
Yuta
Nov 14, 2015 05:02 PM
noobaccord
Oct 25, 2011 11:54 AM
itsnotfast
Nov 23, 2009 02:34 PM
EF9 JAMS!!!
Oct 29, 2005 06:45 AM
Nextelbuddy
10
Nov 25, 2003 06:14 AM
