Gsr water pump HELP!
Old Feb 3, 2009 | 07:00 PM
vtecman's Avatar
Icon2 Gsr water pump HELP!
Does anyone know if I could use a 94-95 integra gsr water pump in a 00 integra gsr?
All the other parts numbers are the same from acura except the water pump is there a difference?
Old Feb 3, 2009 | 07:03 PM
ruffrhyder's Avatar
Default Re: Gsr water pump HELP!
http://www.team-integra.net/forum/di...g+Common+Topic
Old Feb 3, 2009 | 07:13 PM
vtecman's Avatar
That thread only shows the difference between a ls and vtec pump!
Old Feb 3, 2009 | 07:30 PM
FIGARILA's Avatar
does your water pump have 22t stamped on it?
Old Feb 3, 2009 | 07:44 PM
ruffrhyder's Avatar
Oh yeah, that's right, I forgot it compare non-vtec vs vtec. Anyways the difference is a mounting provision since the obd1 and obd2 have different lower timing belt covers. One has a threaded hole and the other doesn't, I can't forget which is which, but look at the 2 part numbers on
www.hondpartsunlimited.com
You should be able to tell from the picture.
Old Feb 3, 2009 | 07:52 PM
vtecman's Avatar
but it work thought on a 00 motor though?
Old Feb 3, 2009 | 07:57 PM
ruffrhyder's Avatar
Did you look at the pictures on the site I gave you, look at number #17 on the diagram, it's found on the obd1 but not on the obd2 price list. That's the only difference. My bad, the lower timing belt thread provision and crankshaft position sensor mounts refer to differences in oil pumps.
Old Feb 3, 2009 | 08:56 PM
ironcheftony's Avatar
yes it will work
Old Feb 4, 2009 | 04:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I believe the 96-01 VTEC water pumps were a different manufacturer than the 94-95. I've only used the one for 94-95 before, but the 96-01 water pump is actually about $20 cheaper.
B00sted Eg2
May 7, 2009 01:34 PM
Egpower88
Feb 6, 2009 06:30 PM
1slowhatchie
Mar 17, 2005 07:50 PM
thaiphob
Oct 31, 2003 05:24 AM
Dorikamu
Sep 25, 2002 07:44 AM
