ASR Reinforcement Bar Help!
Old Feb 3, 2009 | 06:36 PM
rotothedoubles's Avatar
Default ASR Reinforcement Bar Help!
i have a 96 integra gsr
i was installing my reinforcement bar and everything was going smooth until i went to bolt back up my lower control arms.
the bolt that came with the ASR bar meant for that location only goes in 6/8 of the way and wont go any further, any help on how to bolt this back up? its holding the lower control arms up right now but they arent tight and im gonna have to walk to school tomorrow, fast input would help alot
thanks!
Old Feb 3, 2009 | 06:46 PM
j_bizach's Avatar
Default Re: ASR Reinforcement Bar Help!
are the bolts on both side to short or just that side
Old Feb 3, 2009 | 06:55 PM
both sides, its not that theyre too short, they just wont get in lol
the bolts go through the asr bar, the stock hole, the lower control arm, and some where after that it would go
i still have about a half an inch in bolt left on the asr side
you think the stock bolt would work better? or should i just hammer the hell out of it?
Old Feb 3, 2009 | 07:00 PM
j_bizach's Avatar
Fisrt take the bolt out and look through the hole and make sure that ur controle arm is lining up with the front and back hole id imagine that is getting hung up on the back hole cause its not lined up all the way. If its almost prefectly lined up try giving it a few tap with a hammer to get it into the hole but dont smash the **** out of it cause you could end up doing some damage. I dont think that the stock bolts are long enough
Old Feb 3, 2009 | 07:02 PM
haha alright man, before i put the bolt in i made sure to line it up and it went in easily till the other end, ill give it a few hits with a mallet aha
thanks
Old Feb 3, 2009 | 08:34 PM
petwhookie's Avatar
take some weight off the LCA too, itll be easier
Old Feb 4, 2009 | 02:24 PM
so today i went back at it n still had no luck
i unbolted the end links to the sway bar to free up the LCA a little more and still couldnt get the LCA to fit straight
when i looked into the hole to bolt it up you could see that the opposite side of the LCA was high
the ASR side was lined up but the other side wasnt
i tried lowering the car so that the wheels were firmly on the ground, still on the jack tho, and tried bolting it up that way too but no luck
any other suggestions?
thanks
Old Feb 4, 2009 | 02:43 PM
OH_1fstgsr's Avatar
I had similar trouble with one side on my car. I had to take my large 12" Crescent Wrench and twist the LCA while tapping the bolt. The shock for some reason is twisting the LCA.
Old Feb 4, 2009 | 02:44 PM
ill try it out, thanks man
Old Feb 4, 2009 | 06:02 PM
so i got back under my car with my 250 pound dad that lifts
i had him twist the LCA while i tapped/screwed the bolt and still no luck
he was twisting that **** hard too
Old Feb 4, 2009 | 06:52 PM
alphalanos's Avatar
Take some pics. Try removing the wheels. Maybe the bolt is the wrong thread pitch? I did mine with little effort, there has to be some reason its not lining up.
Old Feb 4, 2009 | 07:10 PM
ill try taking off the wheel tomorrow, if no luck still ill take some pictures
without the LCA in place, everything lines up and the bolt goes in easily
Old Feb 4, 2009 | 07:33 PM
j_bizach's Avatar
try putting the bolt through the lower controle arm and see if it slides though that freely if it does then something isnt lining up rite. taking the wheel off is gunna help you alot make thing easier to manipulate
Old Feb 4, 2009 | 07:36 PM
ya it goes threw the LCA smooth
its just not lining up
ill take the wheel off for sure and try again tomorrow
Old Feb 4, 2009 | 08:20 PM
jdmdc2boi12's Avatar
ya id like to see some pics.. its more easier to explain things
Old Feb 4, 2009 | 09:22 PM
codyJDM's Avatar
Never work on any suspension related parts with the wheels on. It takes two seconds to take them off, and saves you hours of useless work and headaches.
Old Feb 4, 2009 | 09:58 PM
EcHoB18C1's Avatar
bump! updates please
Old Feb 5, 2009 | 03:24 AM
OH_1fstgsr's Avatar
Sorry to hear that twisting thd LCA it didn't work. Does some thing with a smaller size like a screw drive make it all the way through? Something just doesn't seem right. Please get some pictures.
Short-cut to my ASR project. Take a look at the pictures. Does everything look the same?
https://honda-tech.com/zerothread?id=2256572
Old Feb 9, 2009 | 11:56 AM
gabebauman's Avatar
Try loosening the other two bolts on each lca yet? (lower shock fork bolt and outer trailing arm bolt) Sometimes just relieving some tension helps.
Rand The Man
Jul 7, 2010 01:53 AM
eg6civic1538
Mar 20, 2008 04:45 PM
DMCCOY
Suspension & Brakes
Jun 24, 2007 03:05 AM
pearlteg
Jan 24, 2005 07:36 PM
KURRRRWA
Feb 6, 2003 10:29 PM
