my gsr compression is 210-210-210-170 what does that mean
Old Feb 3, 2009 | 06:34 PM
vipokc's Avatar
Default my gsr compression is 210-210-210-170 what does that mean
i just did a cold compression test on the motor i got not install and thats the compression what do you guys think is wrong please help
Old Feb 3, 2009 | 06:39 PM
93egSLEEPER's Avatar
Default Re: my gsr compression is 210-210-210-170 what does that mean
could be a stuck or bad ring. does it smoke?
Old Feb 3, 2009 | 07:09 PM
vipokc's Avatar
i got the motor how it sits i was told it was good thats it
Old Feb 3, 2009 | 07:42 PM
you still didnt answer my question.. is it smoking?
Old Feb 3, 2009 | 07:54 PM
kaluwa3's Avatar
It could be a number of things. Like ^ he said is it smoking? Blue smoke = burning oil, white smoke = burning coolant which means a blown headgasket. Is the oil milky and mixed with coolant at all?
sirt_eg's Avatar
you start the car? you have to crank the engine to check compression. Do a leak down test to see if its the valve. if not it might be a worn ring or a bad gasket. add a little oil into the low compression piston, I mean just a little drop and redo your test again, Should seal the rings a little and see if the compression goes back up.
Old Feb 4, 2009 | 06:57 AM
vipokc's Avatar
i got the motor alone ,no shell i did the compression test with a battery to the starter so i dont really know if it smokes are not i will try to add some oil and see if it seals up
AndrewHuffman
Sep 18, 2008 06:17 PM
JDMtype Eg6
Jul 14, 2007 02:31 AM
-HONDA-
12
Dec 19, 2006 10:43 PM
tpdc2
Jul 8, 2006 02:29 PM
VNTEC
May 22, 2004 08:23 PM
