1991 integra b18a1 ***need help***
Old Feb 3, 2009 | 04:22 AM
Falcameno's Avatar
Default 1991 integra b18a1 ***need help***
vehicle is a no start. main fuel relay is new. ignitor, dizzy etc.. all new. i got no injection pulse or fire. cannot figure out how to jump ecu for codes. cant find 2 pin connector. no led light flashing on ecu. fuel pump is good. car just wont fire off. ecu dead maybe? any help would be great.
Old Feb 3, 2009 | 04:51 AM
Import_spoon's Avatar
Default Re: 1991 integra b18a1 ***need help***
So does the vehicle crank or does it give nothing?
Old Feb 3, 2009 | 06:04 AM
neardon's Avatar
I'm a Jackass
Did you take off the metal ecu cover? The 2 pin connector to check your cel is sometimes hiding under that. How did it happen, just randomly one day? Are you getting fuel pressure at the fuel filter? Have you test the distributor components with a multi meter? New ones can be bad.
Old Feb 3, 2009 | 08:32 AM
mpls's Avatar
89-91 hondas/acuras does not come wit that ecu jumper just turn the key to the on pistion and read the led light in the ecu
EdSales
Mar 23, 2010 09:41 AM
civic89si666
Mar 21, 2006 06:05 PM
hybridb18
Apr 9, 2004 04:09 AM
