King Motorsports Vented Valve Covers
Thanks for the comments.
The pricing is as follows:
Option 1. Remove paint from around the proposed area. Drill and clean shards from the baffle. Weld two -10 or -12AN fittings (male) $125.00 or $225.00 for four fittings.
Option 2. Completely strip the valve cover. Drill and clean shards from the baffle. Weld two -10 or -12AN fittings (male) $160.00 or $260.00 for four fittings.
Option 3. Completely strip the valve cover. Drill and clean shards from the baffle. Weld two -10 or -12AN fittings (male) and repaint $210.00 or $310.00 for four fittings.
We had covers on the shelf and ready to go. but customers have yet to return them so this is the only kink in the chain... we expected customers to send them back in a timely manner, so the best option is to send us yours.
We will be buying some more new or used Valve Covers in the future so we can continue with the exchange basis but until then it is best to send us yours. If you have some you would like to sell... contact me AIM = KMSUNLIMTED (Email = robert@kingmotorsports.com)
NOTE: Must add core charge or supply your original cover. The Core charge is refundable once your cover has been returned.
Two (2) fitting covers have fittings installed on the exhaust-side of the cover. We can place these on the intake-side for an additional fee. Four (4) fitting covers have fittings installed on both sides.
Covers that need painting can be turned around same day. Painted covers require one day to cure/
