what size oil feed line for a gt30r
Old Feb 2, 2009 | 04:06 PM
Fastjato33's Avatar
Default what size oil feed line for a gt30r
Just got the turbo and I want to make sure im suppling enough oil to it. It's like 3 16th line coming from the back or the block going to the gauge and the turbo. I have 80psi in full boost and 30 at idel. So I just want to make sure im feeding it the right amount
Old Feb 2, 2009 | 05:43 PM
Fastjato33's Avatar
Default Re: what size oil feed line for a gt30r
bump
Old Feb 2, 2009 | 05:50 PM
TheShodan's Avatar
Moderator
are u using the .035" restrictor? be careful.
Old Feb 2, 2009 | 07:36 PM
Fastjato33's Avatar
It's a small line with the same size a-n fitting going in the turbo
Old Feb 2, 2009 | 08:15 PM
TheShodan's Avatar
Moderator
No.. I'm referring to the feed fitting that goes into the turbocharger itself. I'm not talking about the line.
Old Feb 2, 2009 | 08:22 PM
black_EM1's Avatar
Community Builder
Community Influencer
What he's asking is are you running the restrictor at the oil feed. I'm personally running a -3an line with the .0035 restrictor because BB turbos like the 30R only need about 20psi(don't quote me on this, but it's around there) of oil pressure. More than that and oil begins to leak out of the seals and there goes your turbo.
The feed fitting should be the restrictor. You can get them at www.atpturbo.com, it's where I purchased mine.
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
That's the one I'm using.
092eg6
Aug 2, 2010 01:18 PM
MotorMouth
Mar 20, 2006 07:12 PM
4NBliss
Jul 25, 2005 09:07 AM
Carp
May 8, 2003 04:29 PM
Blown90hatcH
Dec 26, 2001 11:26 PM
