swapping D16 to B16
Old Feb 2, 2009 | 11:16 AM
95 civic b16's Avatar
Icon6 swapping D16 to B16
hey guys im fairly new to the honda scene but have a 95 civic ex and my motor took a dump.....so im getting a b16 and im doing it with some friends .....are there any things that i should be aware of........oh and i want to change my auto trans with a stick...is this really as hard as they make it seem?????
Old Feb 2, 2009 | 11:23 AM
turbojdmhatch's Avatar
Default Re: swapping D16 to B16
https://honda-tech.com/search.php
Old Feb 2, 2009 | 11:28 AM
mpls's Avatar
you will need these from the following 94+ integra all mounts,axles,alt,dizzy,starter,tranny,shift linkage,ecu.your car is a obd1 so just make sure that you get obd1 stuff.the olny thing that you could really used is your harness if its a 5spd but if it auto you have to get a gsr or find a z6 one.and as for auto to 5spd the should be eazy if you just do some research.
Old Feb 2, 2009 | 11:29 AM
ok mostly im concerned with swapping the auto trans to a manual trans any suggestions???
Old Feb 2, 2009 | 11:32 AM
mpls's Avatar
no everything should be fine if you have the right stuff for a manual
im buying a package with the ecu and the tranny....the axles i dont have and the linkage ...where can i find these???
Old Feb 2, 2009 | 11:35 AM
mpls's Avatar
axles and linkage you can used if from any integra 90-01 dont matter if it ls,rs,gs,gsr,type r
Agent_EM1's Avatar
Axles? Go to autozone. I got my B-Series axles at Autuzone for $59 each side, with a lifetime warranty
Old Feb 2, 2009 | 11:36 AM
mpls's Avatar
axle would on a type r
Old Feb 2, 2009 | 11:37 AM
what else exactly would i need for the tranny job???
Old Feb 2, 2009 | 12:04 PM
wait to for the engine i would need a new wiring harness if i want to convert it into a stick shift???
rice a roni
23
Sep 30, 2022 02:12 AM
DA6righthand
Transmission & Drivetrain
Jul 28, 2012 06:44 PM
bigislandc2
Oct 31, 2009 01:01 PM
Winlight
Apr 1, 2008 05:22 PM
bugster
Jan 25, 2005 05:18 AM
