I need some help, car wont start.
i have a 93 civic ex 205,000 miles, d16z6
the car was running great a couple of days ago.
i got 350 miles per gas tank
on sat. it started stalling, i wouldnt rev over 3,000
some people said that the cat might be clogged up, so i straight piped the car, but still it still did the same thing. its a popping sound, and the car has no power.
today it did the same thing and just stopped.
i checked the spark plugs, cables, distributer, all ok
the car sounds like its about to turn on but it doesnt.
i believe its a fuel problem, but dont know if its the fuel filter, or the fuel pump, or maybe the injectors,
how would i be able to tell if its the fuel pump?
it can be ALOT of things. seriously man have you searched? i have seen alot of these threads over the past few weeks.
your timing can be off a few teeth
fuel pump can be slightly clogged
ignition coil might be going bad
bad ground
etc
bad ground
etc
i have, ive found the same thing , fuel problem, but dont really know how to check a fuel pump, or how to check if a fuel pump is working or not. but i am currently working on the fuel filter and spark plugs
PuFFIN420
Jun 10, 2014 08:38 PM
sjteg
Oct 13, 2008 10:19 PM
DC4R27
Apr 14, 2007 04:33 PM
