Hello. need help here!
Old Feb 1, 2009 | 02:57 PM
leechihoo's Avatar
Default Hello. need help here!
My friend and I put the brembo kit on last night. Everything works fine. But the screw under the balljoint will spin. I can not tight it all the way in...Any advise? Where can I get the replacement? Or Do I have to change the whole damn kit??
Old Feb 1, 2009 | 04:30 PM
mymomsdrunk's Avatar
Default Re: Hello. need help here!
you have to use an impact, if you do it by hand it will just spin
Old Feb 1, 2009 | 06:31 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
^yes sir! Need an impact
Old Feb 2, 2009 | 05:37 AM
mustclime's Avatar
The ball joint shaft is tappered , In the past I have put a jack under the lca and I have put a little load on it, this helps you get the bolt tight......fyi, 9 out 10 times this happens, the ball joint is toast. I hope you guys did not use a fork to pop the balljoint, forks and honda lower ball joints do not play well togather....
Old Feb 2, 2009 | 06:01 AM
DaveSi677's Avatar
Impact bro!
HondAcura
Jul 26, 2006 03:46 PM
M2nR
20
Mar 10, 2006 10:24 AM
BryanPendleton
16
Dec 24, 2005 10:54 AM
dj626
Oct 21, 2004 07:13 AM
jschmid
Oct 18, 2004 07:55 AM
