Pic Request + question: Alternator relocation.
Old Feb 1, 2009 | 08:23 AM
street_ride14's Avatar
Default Pic Request + question: Alternator relocation.
I want to move my alternator down into the OE location where the AC compressor used to be. I know Innovative makes a nice alternator relocator mount, any other companies ? + Please post up pics of engine bays if you have your alternator relocated, I just want to see setup and clearance, ..I can use my imagination, but would like to see pictures too. ( h22 engine )
Old Feb 1, 2009 | 08:49 AM
jlude90's Avatar
Default Re: Pic Request + question: Alternator relocation.
http://www.explicitspeedperformance.net/H22Aalt.html
Old Feb 1, 2009 | 09:30 AM
sk8 luder 97's Avatar
what do you have to change, take off to use this?
Old Feb 1, 2009 | 09:37 AM
For the lower relocation mount, you must get rid of your A/C system, mainly the A/C compressor as this is where the alternator will now be positioned. I have no a/c, so I can do this, but for others it might not be worth it.
Old Feb 1, 2009 | 11:32 AM
oranginal's Avatar
edit:
fyi i believe ESP makes 2 types of alt relocate kits, one uses the a/c compressor spot, the other looks to sit a little lower then the stock location. i think the reason they made this was for an h22 in a civic or crx or something. so check out their site, i know it is on there somewhere.
Old Feb 1, 2009 | 11:46 AM
Even lower than the AC compressor location ? I don't think thats possible. Yes they make 2 kits, one at the AC compressor location and one at the Stock h22 location ( ..benefit of this is lighter mount + you can use lighter D-series alternator ). I'm more interested at the kit that relocates the alternator to the AC compressor location. So far it's ESP and Innovative that make these mounts, any other companies ?
Old Feb 1, 2009 | 02:02 PM
meanshyguy's Avatar
What's the problem with where the alternator is located? Isn't this intended for H22 civic swaps?
Old Feb 1, 2009 | 05:31 PM
my use ..To make more room for Turbo-pipe routing.
Old Feb 1, 2009 | 06:39 PM
pheurton-skeurto's Avatar
and the ability to use a d-series alternator which is something like 6 lbs lighter.
Old Feb 1, 2009 | 06:55 PM
meanshyguy's Avatar
That's some good 6lbs you'd be saving, sounds like a good weight reduction idea.
Old Feb 1, 2009 | 08:43 PM
jlude90's Avatar
also a lower center of gravity, and with the smaller alt, its less weight towards the nose of the car.
i saw the ESP one first, but the Innovative looks yummy
Old Feb 2, 2009 | 04:45 AM
Hawkze_2.3's Avatar
In reality the weight loss comes from the brackets weighing less (6 lbs), because the H-series and D-series alts weigh about the same....less than 1 lb difference.
And, just FYI, the Explicit upper D-series mount gives you about a 1" lift of the alternator for turbo or header clearance if that is what you are looking for.
Old Feb 2, 2009 | 05:11 AM
oranginal's Avatar
Originally Posted by Hawkze_2.3
.......And, just FYI, the Explicit upper D-series mount gives you about a 1" lift of the alternator for turbo or header clearance if that is what you are looking for.
in for some pics.
I would love to move the alt up about an inch. need to see the clearance at least in a good pic before i get one, can't just estimate.
Old Feb 2, 2009 | 08:39 AM
Hawkze_2.3's Avatar
Sorry, I don't really have good before/after shots, but here is some pics that show the D alternator and the Explicit bracket. I remember for sure that the new bracket create about 1" more clearance for different manifold. I was planning on using a Lovefab min-me manifold so that's why I switched to the D alt.
Old Feb 2, 2009 | 08:42 AM
my9thtry's Avatar
Check out axlline pictures i know he has some kind of aftermarket bracket
UltRaH22
Sep 7, 2011 10:34 PM
bubxba
Jun 20, 2008 05:23 AM
MassCivicMan987
Sep 19, 2006 08:17 AM
Turbo O
Mar 30, 2006 09:19 AM
teggytegteg
Apr 12, 2005 02:39 PM
