Still no spark!
Old Feb 1, 2009 | 08:03 AM
JDM3STAGEVTEC's Avatar
Icon3 Still no spark!
Car: 93 civic Ej1
Motor: 93 H22A
Ok so about a month and some weeks ago my tranny blew. I replaced the tranny some what weeks later so the car was sitting for awhile. But by just simply replacing the tranny, the car stopped getting spark. I didnt touch anything else besides what I needed to. So then i replaced the ignition coil and nothing. So a few weeks later i got a new dizzy (yesterday) but i noticed inside the old dizzy had two wires that came out of the module that looked like they grounded to the igntition coil. And the new dizzy has those same two wires but they dont come out, they just go with the other wires of the dizzy. So with out a clue i put the old ignition coil in (even though nothing was connected/grounded to it) and still nothing. . . . sooo im just wondering what else could be the reason why im still not getting spark, any help would be GREATLY appreciated. . . . thanks
Old Feb 1, 2009 | 08:16 AM
Default Re: Still no spark!
1 min bump
Old Feb 1, 2009 | 08:19 AM
Sr420Det's Avatar
Sounds like you might of forgotton a ground, did you put the one back on the tranny and thermostate housing.
Old Feb 1, 2009 | 08:21 AM
Former User's Avatar
Does the distributor have 12V at the connector when the key is turned to ON(II)?
Check whether you forgot to reconnect any ground wires, such as on the tranny, thermostat housing, valve cover, etc.
Old Feb 1, 2009 | 08:26 AM
Im gunna check all that RIGHT NOW
Old Feb 1, 2009 | 08:42 AM
how could i check if it has 12v? and my fans turn on when i turn the key but i noticed that sometimes the fans dont turn on and the car doesnt crank but when i turn the key and the fans do turn on, the car cranks, so basiclly it cranks when it wants to
Old Feb 1, 2009 | 08:49 AM
The Blk/Yel wire in the distributor should read 12V. With the ignition key turned to ON(II), touch the red (+) probe of the voltmeter to the Blk/Yel wire and the black (-) probe to the thermostat housing.
Regarding intermittent cranking problems, clean and tighten the battery terminals and ground wire and also check the ignition switch.
Old Feb 1, 2009 | 09:24 AM
Just noticed that my tranny nor my starter were grounded so im gunna ground those and see watsup!
Old Feb 1, 2009 | 09:54 AM
Does it matter what size the wire is for the tranny ground?
Old Feb 1, 2009 | 10:17 AM
Old Feb 1, 2009 | 10:42 AM
citizenEK's Avatar
the ground wire to the tranny should be any smaller than a 10guage wire, 8 or 6 gauge would be a better size to go with though
Old Feb 1, 2009 | 01:00 PM
does it matter where i ground it on the tranny? could i do it on one of the tranny mount bolts?
Old Feb 1, 2009 | 01:13 PM
could it be my ecu? Yesterday i saw that the 15 amp fuse under the hood was blown, and i just noticed that it blew again
Old Feb 1, 2009 | 01:14 PM
G3 shows the location of the transmission ground wire connection:
Old Feb 1, 2009 | 01:22 PM
15A fuse 31 protects the main relay circuit. Disconnect the fuel pump connector to see whether this prevents the fuse from blowing. If so, you have a short at the fuel pump.
Old Feb 1, 2009 | 05:15 PM
ok, i will asap tomorrow, thanks and the tranny can be grounded anywhere on the transmission right?
egsicxxx
Feb 3, 2013 09:15 AM
crfr230
Mar 11, 2007 05:48 PM
D16Y8-JDMYO
14
Oct 29, 2006 11:27 AM
fe519
Jul 12, 2005 08:37 AM
Yambor
Jul 30, 2004 06:55 AM
